Page 4 of 4 FirstFirst 1234
Results 40 to 44 of 44
  1. #40
    Jul 2009
    Quote Originally Posted by the dangling wrangler View Post
    Not that it matters much but, what brand did you go with?
    Goodman, thats what I went with the last time.
  2. #41
    SW Wisconsin
    There are so many things that affect operating EER, SEER & BTUH that this listed matching stuff, IMO in this situation may be way overrated.
    Make sure there is plenty of airflow for a 4-Ton system, many don't have adequate ductwork systems to fully support 4-tons of cooling.
    It may deliver better airflow with two 500-sq.in. each filter racks exterior to the air handler. Use two low pressure loss filters & don't let them load to much.
    In that Houston heat, make that evaporator coil & condenser work somewhere near their Rated capacities to the indoor temp you select, & you'll be a cool dude. Under heavy indoor load conditions, if its not too hot outside, condensers can eject heat well above 48,000-BTUH.
    If it gets too horribly hot outside, with a heavy indoor load, you could, if deemed necessary, block of some of the return airflow.
    Have your tech look up the free air area of the SA diffusers & multiply the FPM velocity times that to get the CFM. CFM times 30 will Ball-Park the BTUH of each branch run.
    Air is king in air conditioning. Whether its a listed match may be rather inconsequential. Many Mfg'ers just use it to bug out of warranties. - Darrell
  3. #42
    Quote Originally Posted by MSP76 View Post
    I don't see anything wrong with that. Others might.
  4. #43
    SW Wisconsin
    Goodman is okay & has a good warranty & it may work as good as the listed match, who knows.
    A couple of SA/RA dry bulb & wet bulb temps & the CFM, & I'll tell him the BTUH it is delivering.
    A comparison to the match performance would be interesting. - Darrell
  5. #44
    Quote Originally Posted by udarrell View Post
    I'll bet ya it's real close to a listed match.
    If anyone here can figure it out, I think you can.
