Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 44
  1. #27
    Payne,meh.
    Should cost less than Goodman. Don't know about the warranty though. If it would even have one.
  2. #28
    DC Metro Area (MD)
    Yes, warranty could be an issue with the mismatch. Payne is pretty similar to the base model Carriers. The ones I've seen appear to be better from what they were in the past, so not bad units, but there is better (construction wise). If cost is an issue and limiting you from putting in a better matching unit, then I would look at Payne or Goodman. That way, in time, you'll be able to replace everything with a matching setup.
  3. #29
    Least expensive (cheapest) will probably be a Nordyne product.
  4. #30
    Jul 2009
    Still, how do I find out if the attic unit has a TXV?
  5. #31
    Quote Originally Posted by MSP76 View Post
    Well, one of two ways. Go up and look yourself, or ask your tech.
    I'll bet the next question is, what does it look like?
    Maybe someone has a picture they could post, or maybe go to the Sporlan, or whoever these days, web site. I know exactly what it looks like but, would have a hard time explaining.
    I think Ryan said it's an obsolete coil now so, I don't know if he could even pull up a picture.
  6. #32
    Dec 2003
    Kenilworth New Jersey
    Easy, Is there a bulb strapped to the suction line OUTSIDE the airhandler?
  7. #33
    Virginia
    the Trane xb is the least expensive Trane model and i do believe can be installed with the correct size orfice that 054 coil should be fine for a 4 ton
  8. #34
    Virginia
    if it had a txv you would probably see some small little tubes were the lines go in the coil
  9. #35
    Google is your friend. Search for images.
  10. #36
    Quote Originally Posted by h2045 View Post
    Not all are on the outside.
  11. #37
    DC Metro Area (MD)
    I think this coil required the field installation of a TXV, so probably on the outside in this case. My understanding is that the new 2TXFH coil has the coil factory installed.
  12. #38
    Jul 2009
    Thank you everyone for your help, the attic unit does have a TXV and I have someone coming today to install the outside condenser. You have all been a great help. Thank you again.
  13. #39
    Not that it matters much but, what brand did you go with?
