    US
    epr and txv adjustments
    hi,
    I am a chiller mech and not a refrigeration guy so I need a little help, I have a system that is single compressor and two coolers and one freezer, epr's on cooler set for 22# (r134) and superheat at coil is 10* and outside near epr superheat can range from 10 up to 23, can epr vales back up refrigerent and flood suction line with liquid up stream of epr to show high superheat, and will this cause liquid to trickle into suction line and show almost no superheat at compressor even though it is at 8* at all evaps??? I hope that is enough description to get an answer, please post any more info needed
    Jun 2009
    texas
    epr
    yes it can happen, you should try opening the epr up and see if it goes away then readjust.
    Southold.calm
    Quote Originally Posted by 9675 View Post
    hi,
    You’ve got the post count, now apply for Pro Membership.
    I can’t and won’t answer your question here.
    florida
    X2.Apply for pro Membership.
    Educational forums are open.
