Results 14 to 15 of 15
    Northeast Ohio
    Your installer just needs to spend a little more time confirming charge and air flow. TXV means he HAS to charge using super heat / sub cool methods. As far as sweating, only an indication that you are too hot.
    DEM
    SW Wisconsin
    The indoor split is contingent on the humidity level.
    If the indoor humidity is high, a 16-F split would be okay.
    The normal blower position blows air through the coil, & therefore the only increase in its percentage of normal air pass-through (by-pass) would be due to the increase in velocity & CFM through the indoor coil - with blower door-panel removed.
    If the blower is drawing air through the coil, with blower door removed, it could be a near total by-pass of the indoor coil. The TXV would shut the liquid flow way down helping to protect the compressor; a fixed orifice metering device would in a short time, be a major liquid slugging threat to the compressor.
    Check duct system for air leaks & check for required airflow, correct CFM if needed, then charge using Subcooling & verify TXV's specified Superheat setting.
