Results 1 to 11 of 11
    Wichita, KS
    Poor Cooling on 3rd Floor Apartments
    Original call: AC just can't keep up in the heat of the day. That last pic is where the siding has rotted out and pigeons have taken up residency in the walls. The only thing separating the apartment and the 100 degree heat is 5/8" sheet rock, and a little insulation the birds have yet to remove.
    Pic 3: Don't we all wake up every day enthused at the prospect of getting on a roof with 3" of pigeon poop?
    Jun 2008
    NW Florida
    Is there a dryer vent close by.
    I would recomend to the customer that the electrical is unsafe and note it on the work order and make sure you get a signature. Just to cover your own butt.
    May 2009
    watertown ny
    wow thats the dirtiest condenser Ive ever seen
    TIP-O-TX
    Condenser Blanket?
    I've heard of compressor jackets but not condenser blankets. It might make a good blanket for winter.
    Nov 2002
    Manly, Iowa
    what was the head on that condensor?
    Learn the process not the procedure--the process will dictate the procedure-If ya understand how it works ya knows how to fix it!
    SO what was the problem,
    Was it low on "freon" pre the HO
    Jun 2008
    NW Florida
    I have seen one just about as bad. Lady had 5 persian cats that laid beside condensor. Was easy to clean though just peeled off a solid mat of cat hair.
    Unit looks to be a Rheem.
    SW Virginia
    probably just the thermostat.
    Portland, OR
    I do believe Mrs. Push is gonna get a shiny new down pillow fer her birthday!
    british columbia
    i never knew you were supposed to put a filter on the condenser they shouldve at least changed it !!!!!
    Canon City, Colorado
    They must have forgotten to remove the condenser blanket for the summer!!!!!!!!!
    Any job big or small,do it right, or not at all !!!
