Results 1 to 12 of 12
    Jul 2009
    Hmm Blowing fuse about every three days in the heat of the day
    I am working on a heat pump with a scroll and it is blowing the main fuse. I
    replaced the cfm, bfm, comp cap, and contactor that were all in very bad shape. the compressor running amps are good. Lock rotor amps are good when I am there. What am I missing is the compressor getting stuck internally on occasion?
    Jun 2009
    Hurst, Texas, United States
    Maybe the fuse/breaker is unable to hold the amps when other loads are running while the a.c is on...too many loads on one path...?
    Jul 2009
    That is a good thought, The amps check out its pulling 35 amps at the disconnect and blowing one of them. I put a 45 amp in to see and three days later it blew.
    Dry as a bone Tucson
    fuses
    Check your wire size, junction boxes, breaker clamps, and voltage when unit is running. Also sometimes breakers need a break too.No just kidding? Breakers do go bad.
    Watchman Nee
    Jul 2009
    Is it possible after checking all the above that the compressor could have a problem
    Jul 2009
    I realize its not an everyday thing
    Jun 2009
    well if you put a new cap...it shouldnt be the compressor...like acfixer said check your wire size...ect...
    5,000 ft
    Is there a TD in the stat or the ODU? If not, might be trying to restart to soon b4 equalizing.
    5,000 ft
    Use your infrared to check for loose/failing connections at fuse holder and line connections.
    call a professional
    Dec 2003
    Kenilworth New Jersey
    I`m with Steve, there is an overheating connection someplace
    I agree with Beachtech, call a service tech.
    Sorry, this is not a DIY site. So we are not allowed to give out DIY advise.
    Please read Site Rules Thank you.
    Thread closed.
