Results 1 to 13 of 13
07-03-2009, 10:10 PM #1
- Aug 2008
- 107
Any benefits in going with R22 at this point
Are there any benefits in going with R22 systems at this point? The unit is a Trane 14i heat pump. The air handler is going to be installed in a second story attic. The lineset will not be replaced (flushed). One of my main concerns is the cost of R22 going up. Trane gives a pretty decent warranty, but it does not cover refrigerant costs. The other downside to an R22 system is that there is an option to replace just the condenser in the future if I go 410a. This shouldn't be that much of a concern though. By the time the warranty runs out, the air handler will need to be replaced. There are situations, however, where the whole condenser would need to be replaced (hurricane damage, etc.).
Are you guys still installing a lot of R22 systems? I just wanted to see what the pluses and minuses are.
07-03-2009, 10:30 PM #2
- Sep 2002
- I don't know
- 2,888
If your system gets put in by a competent installer R410 has no disadvantages over R22.
07-03-2009, 10:38 PM #3
New Guest
- Apr 2008
- South Carolina
- 1
R-22 systems can be installed until 2010. R-22 refigerent will still be produced until 2020 for existing systems. The price of r-22 will increase some but after 2020 a large price increase will be expected because the only r-22 refrigerent will be reclaimed. This is refrigerent that has been recycled and brought back to a like new grade.
07-03-2009, 11:04 PM #4
i dis-agree....410A is a mixture of different refrigerants...so if/when you have a leak you dont know which refrigerant was the one that leaked out first...so you have to evacuate the system and put new 410A refrigerant back in the system...that one dis-advantage also 410A has alot higher pressure than that of R22... R22 systems will still be installed until 2010 then will be phased out...but the refrigerant will still be around...for awhile at least....
WHO DO I TRUST.....ME THAT'S WHO!!
07-04-2009, 12:08 AM #5
- Jun 2009
- Kamloops B.C.
- 31
DPeoples Do you not evac and repair all leaks anyways ? read your awnser again every leak needs to be repaired to repair you need to evac and re braise the leak so what does it matter what leaked.... Puron R-410 is way better option to 22 at this time (think about the future)
07-04-2009, 01:16 AM #6
- Nov 2006
- Maui
- 5
basically the only advantages to putting in r22 systems now is the low cost of replacement at this time, compared to replacing the whole system with 410.. i guess based on the customers' budget.. we dont even install r22 systems anymore for new installs.. why do it?
only for repairs, i've been asked to just go with r22 condensing unit because the air handler is still in great shape..
07-04-2009, 01:27 AM #7
tranes optional extended warranty pays for refrigerant. it pays the contractor for everything "within the panels" and the thermostat
is this an existing 14i?
cause the 14i isn't made anymore, and has been obsolete for over a year in th XL platform. is an XR14 now
and if you're buying new, no there isn't a good reason to go with 22 inless you plan on doing extended warranty
http://www.youtube.com/watch?v=nFl0n...ture=endscreen
07-04-2009, 01:28 AM #8
most all of tranes resi 22 systems are already on special order, and trane is stating that august will be thier cut off for 22 systems... heresay? maybe, but i believe the source i heard it from
07-04-2009, 01:59 AM #9
- Sep 2002
- I don't know
- 2,888
Apparently topping off 410a doesn't pose a problem - http://www.hrai.ca/R410A/char.htmi dis-agree....410A is a mixture of different refrigerants...so if/when you have a leak you dont know which refrigerant was the one that leaked out first...so you have to evacuate the system and put new 410A refrigerant back in the system...
I wouldn't trust an HVAC technician who tops off leaking systems anyway.
07-04-2009, 02:39 AM #10
07-04-2009, 06:04 AM #11
- Mar 2008
- SW Virginia
- 15
Go with the 410a, you'll be glad you did in the long run
07-04-2009, 08:06 AM #12
07-04-2009, 08:21 AM #13
