Thread: Break in Time
    Aug 2008
    Break in Time
    Do new HVAC systems (HP in this case) have a "break in" time? Perhaps its just me but t he HP seems to be cooling better than at the beginning of the summer
    Oregon
    I've never heard of a break in period.
    You need to be careful with comparisons. Performance will be a function of ambient temperature, humidity and the rate at which heat is infiltrating the dwelling which can be a result of many factors such as radiation. (sunny day vs overcast day)
    If your comparison is based on feeling the outlet register temp then it could also be a result of lower airflow across the coil. Has the filter been changed since the system was new???
    Apr 2008
    Northwest Arkansas via Chicago Area via Straight Up from There on Lake Superior
    Quote Originally Posted by AvantGarde View Post
    I do recall several posts in other threads that say the system needs to learn your house. Don't know what that means but I would be curious to hear an explanation.
    Jun 2007
    The Twilight Zone
    Quote Originally Posted by jerryd_2008 View Post
    That would probably be for a digital t-stat with "Adaptive Intelligent Recovery". Not the HVAC system, just the t-stat.
    Take care.
    Aug 2008
    Thrice since Feb
    Quote Originally Posted by davefr View Post
    Very ticky
