    May 2009
    What kind of duct is this? How to re-connect
    Besides old and ugly - I was wondering what type of duct is pictured on the right. It seems like just a browish/black paper covering fiberglass.
    Basically, the two duct types have pulled apart on this supply duct, and cold air is leaking into my garage.
    What is the best thing to use to connect the two back together? Duct tape OR tape coated with mastic or duct sealant?
    Thanks!
    Jun 2009
    The duct you have appears to be sheet metal with fiberglass insulation. Sorry but no DIY here, although if you go to an AC supply house and ask they will give you exactly what you need.
    Should be a quick fix, but looking at that duct it may be time to rip it all out and replace it. I recommend a professional for that since it's a hot miserable job and the pros can get it done much faster/better than you can.
    Arizona
    Twenty five years ago we called that FS duct. Its ridged fiberglass duct, its also junk!
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Seen it on space pak systems, crap comes apart and develops pin holes.
    The South
    Not much fun to work with.
    GO DAWGS!
    May 2009
    Quote Originally Posted by HVAC9900 View Post
    What's that? Rigid fiberglass duct or space pak systems?
