Results 1 to 7 of 7
    Question HELP -- ASZ16 Install split level question
    My upstairs split level HP is broken. A local HVAC group came out and quoted several options (Goodman, Amana, Ruud). I decided to go with the Amana ASZ16 because of the efficiency, reviews, variable speed blower, etc. Now the contractor is coming back saying they cannot install this unit due to wiring issues (house was not originally wired for variable speed unit, etc.) 2 stage compressor, etc. Is this a real constraint, or just a cost issue (i.e. too hard)? Your advice is greatly appreciated....Thanks.
    bucks county, pa
    Not quite sure what he means by not wired for V/S, what would he do if it were a complete new install?
    Sounds fishy to me
    Houston, Texas
    Hard to give an honest opinion.
    Nobody here can "see" the job.
    Have you tried asking them first?
    Jun 2007
    The Twilight Zone
    Does the the thermostat wiring need to be re-done for a 2-stage condenser, i.e. needs an extra wire?
    Lancaster PA
    Most need more then just one extra wire.
    Shouldn't be hard to get teh extra wires to the outdoor unit. On a regular home.
    As far as the wires to the thermostat. They can use a Honeywell IAQ, or a Honeywell wireless thermoststat.
    May 2002
    Houston Texas
    They can use a wireless device called instant wire or something like that. It will add up to two additional wires to the t'stat and to the condenser. i will try and find the name, I have used them and they are very easy and reliable.
    They can get them from Johnstone.
Tags for this Thread
