Results 1 to 10 of 10
    , had my own business for 30 years
    Help needed on a Groen tilt pot
    I got the thing working, it had a loose wire on the thermostat, but neither the Chef or I know how much water to add, the pop off valve burps it out when heated up. I guess it could be weak, but I don't have a book on it and the slugs at Groen won't return my phone calls.
    Any help appreciated.
    Jim
    Lake Worth, FL
    Usually the pressure relief valve pops off if it overheats, the valve is weak or too much water is added. Wihout the model number I cannot tell you how much water to add. When adding water ONLY use distilled water.
    Thanks for responding, how much water should we put in, low on the sight glass? I understand the gage should read in a vacuum if properly balanced.
    We are using distilled water (We being the Chef and I, the serviceman.)
    Those slugs still haven't got back to me from Groen.
    Jun 2009
    Davie, Florida
    Groen Tilt Kettle
    Along with the distilled water you should use a rust inhibiter, Groen and Cleveland does not sell this rust inhibiter; you can use a product called Borex; they sell this in Home Depot.
    As far as the amount of distilled, if it is a 80qt kettle then 8.5 gallons, 60qt then 6.0 to 6.5 gallons. If you need a PDF on the kettle get me the model.
    Good Luck.
    I appreciate your help, you are probably successful at your job. A helpful attitude is good in this business.
    Model TDB 7-40 Serial 15975 1990-91 208-230 3 Phase 30 amp.
    Thanks, Jim.
    Jun 2009
    Davie, Florida
    Groen TDB 7-40
    Takes 5-quarts of distilled water. Attached is the PDF service manual for this model, any else let me know.
    Quote Originally Posted by propclub View Post
    Thank you, but I don't think the attachment made it.
    Jim
    Jun 2009
    Davie, Florida
    Groen Attachment
    The file is to large for this format, if you want the manual send me an e-amil at dkirmse@levelonetechnical.com and I will send it to you.
    Lake Worth, FL
    you mentioned about a sightglass on this unit. Water only halfway up the sightglass. Don't add more rust inhibitor unless you lose almost all the water. To put the system in a vacuum heat it up for 5-10 minutes and then momentarily release the pressure relief valve. DO NOT release the valve when cold or you will lose the vacuum.
    Thanks Pairman, I will pass that on.
