Results 1 to 13 of 14
    May 2009
    queens ny
    cyclinder question
    will i be able to connect my gauges to the system and my yellow hose to the cyclinder without a recovery machine?? the unit is working but i need to remove the refrigerent
    Jun 2007
    The Twilight Zone
    You have the post count.
    Apply for pro membership.
    bucks county, pa
    No
    May 2009
    queens ny
    Quote Originally Posted by gary_g View Post
    lol what does that mean? am i all good? no machine at all it ll flow right in right?
    May 2009
    queens ny
    o boy
    Fort Worth, TX
    You need to remove ALL of the refrigerant?
    And you want to do it without a recovery machine?
    Not recommended. At all.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Jun 2007
    The Twilight Zone
    Quote Originally Posted by SixInOne View Post
    It means that you need to apply for pro membership because questions like yours are not typically answered in the open Residential Forums.
    I'm surprised that the Mods haven't closed some of your posts.
    Take care.
    May 2009
    queens ny
    if i had a choice to buy a recovery machine or a vacuum pump which is used more in the field i cant afford right now tobuy both so iwill get one
    SW Wisconsin
    You have to have both.
    There is no way to know which will be used most, but both have to be used when the proper procedure calls for it to be used
    Perhaps HVAC Supply distributors, or other sources, should provide rentals, ha. - Darrell
    You NEED both. At the same time. Not optional, required.
    Hate to pop your bubble, but that is the way it is.
    You do need both.
    Read this, one of the educational guys posted this in another thread. It's interesting.
    An excellent story.
    http://www.alder.co.za/raca_article.pdf
    They don't serve the same purpose. They each have their own function.
    So you need both.
    Its an EPA requiremet that you have access to a recovery machine to work on refrigerant containing appliances.
    A recovery machine can't pull a vacuum good enough for use as a vacuum pump.
    So you NEED both.
    Jun 2007
    Darby, PA
    Look out!!
    Psalm 51:10, 12
