Results 14 to 26 of 30
Thread: Looking for ansewers..
07-01-2009, 07:39 PM #14
- Jun 2009
- 7
Looking for answers
Thanks for all the great comments and advice. I did get a hold of an American Standard Rep. He knows the installer. He is going to get with him to get all the info on the repair work. He was telling me that they have had similar problem in Seguin TX because of sulfure. Most of south Texas has sulfer in the water. The curious thing here would be there are 4 houses here, all have central air units. The other 3 are less than 3 years old, and none have ever had any problems at all. They too are all American Standard units, the only difference is they all use the R-22 refrigerant. Mine the one with all the leaks uses the R-410a. I will update as soon as hear from the rep.
07-01-2009, 07:48 PM #15
Professional Member*
- Dec 2004
- newton,mass.
- 6,109
"Nothing else can poison our culture, corrupt our society or ruin the character of our people like unearned money or unearned opportunity." -- James R. Cook
"Fooling around with alternating current is just a waste of time. Nobody will use it, ever." Thomas Edison, 1889.
07-01-2009, 10:21 PM #16
07-01-2009, 10:23 PM #17
07-01-2009, 11:09 PM #18
- Aug 2007
- Clearwater, Fl
- 355
American Standard/Trane has a program in place for extended warranty evaporator coil replacements. Any evap coil, regardless of age that is replaced under extended warranty gets sent to the factory to be tested.
If they cannot confirm the techs diagnosis the warranty claim is not paid, and the contractor eats the complete cost of the work performed and materials used, including the coil.
I don't think that many coils will be sent back without the contractor being absolutely sure the problem was properly diagnosed.If people only focused on the important things in life there would be a shortage of fishing poles.
07-01-2009, 11:16 PM #19
Off topic, but I have to ask it. What is an ansewer?
By the way, I work for a company that sells Trane as it's primary system, and I have come across quite a few of them that had leaks. Maybe about 5 or 6 in the past 2 years, but it does happen. However, 6 times in a row? That's just preposterous.nagakatta yo mou sukoshi de atatakai hizashi abireru, honto wa gutto koraete'ta jibun ni dake wa makenai you ni, nagakatta yo mou sukoshi de atatakai hizashi abireru, hanarete sugoshiita jikan ga samishiku nakatta to ittara uso ni naru...
Not as lean, not as mean, but I'm still a hardcore, ass-kicking, hard charging Marine! Oohrah!
10-16-2009, 08:14 AM #20
- Jun 2009
- 7
Hi Everyone,
To reinterate from the last time. I talked to the factory rep,(Stuart), at American Standard. We went trough the whole thing about the sulfur in the area and all. He mentioned "Sick building syndom" and that they really don't know what is causing the failures of the evaporator coil. I checked the Chinese sheetrock theory. That as with sulfur will turn the copper black. Thats not the problem because the copper is pristine. Long story short, they came in and replaced another coil at the end of June. It too has since failed. This one in just 4 months. The installer who has an excellent reputation and American Standard swears by him, says there is no indicatiion of any corrosionon the coil. It will develope these leaks that are just a pin hole, and I think he told me usually only one. He thinks it is some kind of chemcal reaction to something in the house. I tend to disagree. I have gone through the house and cannot identify anything that is uncommon to other households. I'm certainly not an expert in this matter, but is it possible there might be some sort of electrolysis? There is no problem with the refigerators in the house, just the A/C unit. I'm wondering too, if just simply replacing the intire unit wouldn't solve this dilemma. Since there is no indication of corrosion, maybe its something wrong with the unit itself? I would appriciate all of you thoughts once again, and thanks so much. Paul S Cardwell
10-16-2009, 08:25 AM #21
the unit itself?
10-16-2009, 08:51 AM #22
- Mar 2005
- Houston, Texas
- 11,654
What's gonna happen when the warranty expires?
Had to add this.
http://news.yahoo.com/s/ap/20091015/...hinese_drywall
10-16-2009, 09:17 AM #23
- Aug 2007
- Clearwater, Fl
- 355
Last month we replaced the third coil on a system that was installed in 2005. Coil # 4 is an epoxy coated coil that was supplied to us by Trane and should eliminate this issue if it is a problem with the exterior of the coil. It does raise another issue of possible increased mold growth on the coil though. We will have to wait and see how this coil works.
You may ask about a coated coil to protect the surface area from anything that may be in the home.
I have also heard rumor of a full aluminum coil becoming available in the first qtr of 2010.If people only focused on the important things in life there would be a shortage of fishing poles.
10-17-2009, 07:02 AM #24
- Jun 2009
- 7
forcryinoutloud,
Thats interesting. You know a few years ago they did install one that was coated. I don't know what it was coated with though. I'm sure it must have been the same thing. It too developed a leak after about 9 months. Wouldn't this indicate that there must be some sort of internal problem? I mean the coating is applied to protect the copper and aluminum from corrosives. So what ever is eating at this is not selective at whether it is copper, aluminum, or even epoxy. I would think it that it must be caused from the inside out?
10-17-2009, 07:17 AM #25
- Jun 2009
- 7
The Filter is located directly in front of the main unit. This unit is in the attic, so the return air duct comes in from two smaller loctions, and one large one directly under the unit on the ceiling. The filter is behind a door you remove to slide the filter out, a somewhat large filter, about 24x24x8. When I change it, I can see the coil. you know provided you shine a flash light in there.
10-17-2009, 07:35 AM #26
Change hairspray or cooking oil or get rid of the dog. Ya gotta change the contributions to the formic acid.
No reserve. No retreat. No regrets.
For those who have fought for it, freedom has a sweetness the protected will never know.
http://www.airwarvietnam.com/16thSOSGunners2.jpg
Proud member of KA Club
