Thread: Derating furnace - adjust pressure or change orifice?
    Jun 2009
    Albuquerque NM
    For derating a furnace, what iss the correct method - adjusting pressure or changing the orifices, or both?
    I'm at 5000ft. I suspect my furnace wasn't derated when installed. Would I save money if I had someone adjust it?
    SE Iowa
    The installation instruction of all furnaces give details on how to adjust for higher altitudes. You should have het installer return and set-up te unit correctly... or pay a pro to do it.
    Incorrect airflow can cause improper burn resulting in higher CO levels, soot, and lower efficiency.
    Dry as a bone Tucson
    Quote Originally Posted by garya505 View Post
    Both need to be done by a pro.
    "I aint going to spit on 30 years of my life" Monte Walsh
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
