    Jun 2009
    Cool SEER rating from 1998 Comfortmaker?
    Does anyone now what my SEER rating on my 1998 comfortmaker central air unit might be?
    There are 2 model #'s on the unit: acs042a2c1 & fba042gc1
    Mfr # nacs042a2c1
    serial# l982363817
    I'm thinking about upgrading to a new central air unit and want to know what type of saving I might be able to get with a new unit (based off the seer ratings). Only to give me a rough idea... I live in the midwest.
    Thanks.
    Burleson, Texas
    10 seer
    SW Wisconsin
    Quote Originally Posted by ktiberg View Post
    Mfr # nacs042a2c1m serial# l982363817
    Thanks.
    Don't get hyped up on those SEER charts, every situation is different & nobody can predict what the savings might be for your particular situation & run-time hours per season.
    I personally liked the 10 & 12-seer equipment.
    When properly installed they worked well, especially in higher humidity climate areas.
    Unless you live in a climate with many A/C months & runtime hours; work on optimizing the operating efficiencies of what you have & reducing both the heating & cooling loads.
    Checking ductwork & airflow, reducing home air infiltration, (<-Both huge factors), adding foam & other insulation & attention to windows & doors will save energy use & utility costs the year-round. - Darrell
Tags for this Thread
