Results 14 to 26 of 41
    May 2009
    Earth
    That is a breath of fresh air compared to the stuff I see in the field.
    very nice work......just have one question. do you guys use clear pvc primer. i always afraid to use it b/c i think the inspector will question whether it was use or not. it makes the job look so much cleaner.
    "The things you own end up owning you. "
    Tyler Durden
    Indiana
    yes clear..plumbers also use clear...not a code here
    Jun 2008
    chicago suburbs
    excellent work...except the outside unit disconnect looks crooked..
    learn from yesterday, experience it today, gain knowledge for tomorrow.
    -Amech
    Mar 2002
    fort walton beach fl.
    very nice piping!!!!
    May 2009
    Planet Earth
    It's really nice work as I indicated in my earlier post; however I just noticed the disconnect on the wall is out of plum. What up with that? Electricians couldn't get it right?
    Indiana
    the disconnect is from the original condenser that sat there...no one knows where the electrician went or when he is coming back...I hope he does not hack it all up i can just imagine 15' whips instead of nice hard conduit...or worse yet have them screwed to the condensers
    very clean!
    HVAC PRO IN THE MAKING
    NATE's:
    Gas Heat Service/ Installation
    Air-to-Air Heat Pump Service/ Installation
    Air Conditioning Service/ Installation
    Apr 2006
    Chicagoland
    Sorry - yesterday was the deadline for all complaints.
    Jan 2006
    Bryant AR.
    Thumbs up
    Man, What would it cost to send my installers to train with your guys??? I can't even get them to wear a hat straight...forget refrigerant piping!!!
    After finding out our second born was also a boy, my wife asked "why are you sooooooo happy" to which I replied; "2 of those things are easier to keep up with than 20,000!"
    Metro Atlanta
    No substitute for hard pipe and unistrut. I do not use linesets anymore and this job is a perfect representation of why. Hope yall did a good leak check on all those joints! One more thing, that must be 410A, did yall purge with nitrogen while brazing? I believe its more crucial with POE oil.Our install guys never do but most of the service guys do.
    Indiana
    nitrogen purge...huh? lol I asked them a wile back about it..they just gave me a goofy look. they pressurize with nitrogen to 100lbs then check it after 15 min. If there is a tiny leak usually i find it at start up when i call and ask "did u pressurize this?" They take pride in there work that is for sure.
    Metro Atlanta
    i didnt mean leak check with nitrogen, i meant "purge" while you were brazing to eliminate oxidization inside the piping. Our install guys give me the same goofy look or they tell me how they have done this for years and its been ok without it! Reguardless if it works without it, its a good habit to get into. And if those units were 410A they should pressurize with a lot more than 100 psig for leak checking, more like 350-400 psig. It probably won't matter but it wouldnt hurt!
