Page 2 of 12 FirstFirst 123456789 ... LastLast
Results 14 to 26 of 144
    Jersey
    thanks for this post, I was looking into this stuff, It is in alot of the trade magz, and tought about it, I was looking for someone that had tried it. I am sorry that it had to be you..
    Note to self, Not to use the crap.
    Ride hard on a Harley!!
    Dry as a bone Tucson
    got some crap
    I bought some just in case, but I never got the guts to use it,it just didnt seem right to put something similar to a tire sealant into a nice clean system.Thank you Jesus for not letting me use that crap!
    Watchman Nee
    Mar 2009
    Quote Originally Posted by ACFIXR View Post
    I have a system where one of the past residents used bleach to keep her condensate drain clear. I've been able to patch up two capillaries but I still have a pinhole leak in there somewhere and have been tempted to use this stuff...sigh...guess I'll hafta get out my sniffer and find the leak
    (The wise men of modern thought) adore a god made of putty or of wax - plastic, effeminate, molluscous, with no masculine faculty about him, and no quality that entitles him to the respect of just and honest men, for a being who cannot be angry at wrongdoing is destitute of one of the essential virtues, and a moral Ruler who is not angry with the wicked, and who refuses to punish crime, is not divine. ---Spurgeon
    Quote Originally Posted by mike robinson View Post
    I have had no problems been using it for three years you have to follow manf. instructions when looking for leaks you always change the drier after all where do you think all the moisture and air go. Super seal reacts to these type of things.
    Do you mark the system so the poor schmuck who comes along after knows to walk away before installing his gauges or recovering that stuff?
    North Carolina
    Quote Originally Posted by Reeferman View Post
    My thought's exactly!
    Had a HO who is an auto mechanic ask me about it once. I told him, sure they make it for resi unit's. It's a last ditch patch that may or may not work. You want it, you buy it. Put it in yourself & don't call me when your unit dies. I don't want it in my guages or my G5. I was polite and respectfull & meant every word. He opted for a new evap coil.
    Aug 2009
    Seabeck, Wa.
    "I have a system where one of the past residents used bleach to keep her condensate drain clear. I've been able to patch up two capillaries but I still have a pinhole leak in there somewhere and have been tempted to use this stuff...sigh...guess I'll hafta get out my sniffer and find the leak "
    Dang, I hate to see anything in a cap unit, even dye!
    Not having any luck with the quote brackets. Have to research that a bit.
    las vegas
    supposedly calgon has a similar product out now. he gave me a sample
    but havent had the right situation arise yet where it is a last ditch effort.
    if anyone has tried it please post.
    NC
    I used that product once on 4 ton water source heat pump. That was about four years ago and haven't been back to the unit since. The unit is still chugging along problem free. And yes, a label is included in the box that you can stick to the unit indicating that the super seal is in the system.
    Apr 2006
    South West Ohio
    Its like anything else. If you dont follow directions, There is a good chance of failing. We have used it on a couple systems on their last legs. We advised the customer against using it, and if it worked it worked. If it didn't then it was time for a new system. (these systems are over 20 years old) We have never had a problem with it. Do I want it in my geothermal 27 seer unit. NO. Would I use it on my 20 year old air/air system to get thru summer. Yes.
    May 2008
    Missouri
    Have used it 4 or 5 times with horrible results each time. Last couple of times we replaced all dryers and evacuated really well, and still lost both compressors. Don't use it!!!!!!!!
    Jan 2002
    Confused
    jdblack
    I have researched the product and spoke w/ cliplight tech to know more before I use the "total 2".
    Is it possible that the drier used was saturated w/moisture?
    I have found / used many such driers. Using them on a sys. w/holding charge overnight and the nearby SG showed wet.
    Alco sweat driers are problem due to their bleed hole in the cap-hard,black w/knurls (hidden from view-But found with bubble solution). Alco said they were there to prevent the caps from popping off during their painting procedure.
    BTW
    Per Cliplight
    THE sealer exist only as bound to the refrigerant.
    It is removed as the refrig. is removed.
    florida
    It's still crap.
    Educational forums are open.
    Jul 2009
    Connectitaxed
    Quote Originally Posted by crackertech View Post
    It's still crap.
    When will the fools ever learn?
