Results 1 to 13 of 28
    Oregon
    Monitor top conversion from sulfur dioxide to R-12
    My fridge developed a sulfur dioxide leak in the evaporator. Here's my completed conversion to R-12. I cheated and performed a heart transplant.
    Oregon
    This was the donor.
    P.S. Antique refrigeration is a PIA!!
    Phoenix,AZ
    Do you mind explaining how it worked originally? I never heard of sulfur dioxide, nor do i know what that thing is on top of the fridge.
    Why didn't you keep the evap and float?
    and go to 134 instead of 12?
    PHM
    PHM
    Oregon
    PHM
    The evaporator is rusted out (see image). Besides that the mineral oil used in SO2 refrigeration units is likely not compatible with PAG used in R134A systems.
    I'm pretty sure my compressor is OK unless the moisture sucked in, (ie SO2 evaporators operates at less then atomospheric pressure), caused an adverse sulfuric acid reaction inside the hermetic unit.
    The stubs from the condensor are crimped shut should I ever find a replacement evaporator. For now R-12 works just fine - at least the beer is cold!!
    Oregon
    Quote Originally Posted by kbghdg View Post
    The top part is the hermetic compressor unit with the condensor coils circling around it. The evaporator is a similar to modern evaporators except it's cast iron and prone to rust.
    They used a float to control the liquid refrigerant entering into the evaporator. (kind of like a toilet valve)
    SO2 is miserable refrigerant to work with. A few strong huffs and you might be dead. These monitor tops are pretty robust but imagine a major refrigerant leak back in the 20's when people lived in very small houses. If the obnoxious smell didn't wake you up in time you'd likely be dead. SO2 refrigeration units were like a chemical weapons inside of homes. Freon R-12 was a godsend given the primitive refrigerants at the time.
    The later model monitor tops had stainless steel evaporators and were much safer however I would not put them in living quarters - the garage is close enough.
    What were the ones with the bronze evaps?
    They looked like that one you pictured but were all bronze. What refrigerant did they use?
    PHM
    Oregon
    I have no ideal. Maybe methyl formate or anhydrous ammonia. However I don't think GE did ammonia.
    Ammonia tears up brass
    So maybe methylene chloride? I was just curious. All the one's I've ever seen were dead empty and after I fixed the leaks I charged them with R-12. When it was a dollar per pound. <g>
    PHM
    Quote Originally Posted by davefr View Post
    PHM
    Sep 2011
    waterford ny
    I have a monitor top that the gas is all leaked out. I like your conversion and would like to do the same thing? I can get a small refrigertor like the one you used on craigs list that works for $25.00 is there any thing i need to know before I buy it? The coils are mounted on the back like the one you show. Will I have to disconect the lines to install every thing and then recharge the system or can i get away with out doing that? where did you install the on and off switch? <Email addresses are not permitted in post, please put it in your profile, thank you>
    Nov 2008
    Hudson Valley, NY
    the C-A modle had METHYL FORMATE in them bad stuff stay away !!!!!!!!!!!!
    Sep 2011
    waterford ny
    C-a ?
    Quote Originally Posted by A1 Burt View Post
    C-A Modle ? The amonia deoxide is all leaked out ? I am going to try the coversion taht you show?
    Oct 2009
    Raleigh, NC
    Why is Methyl Formate "bad stuff"? I mean, it is a toxic chemical, but it isn't dangerous when handled carefully. It is even a liquid at room temperature. I would think ordinary gasoline is much more dangerous.
