Results 1 to 8 of 8
    Jun 2006
    steel condenser coils
    This is the first time I've seen a leak in a steel condenser coil. I wonder if its cheaper to replace the condenser then the coil.
    Foolish not to replace the whole thing. Do you want to be married to that old hag?
    Howell, Michigan
    Thread moved into Refrigeration!
    Jun 2006
    New Jersey
    Im sure replacing the condensing coil would be cheaper, but look at the condition of the condenser. The receiver is rusty bad, that low pressure control has seen better days, and it looks like it's seen at least one compressor replacement. In the long run, replacing the condenser is a cheaper option.
    Banana Republic,Florida
    its time to offer them a new system man its seen better days
    Mastic its whats for dinner!
    Apr 2008
    la puente,ca
    i agree on replacing the condensing unit or jus welded it(silver solder) and move on to the next call
    Apr 2009
    Australia
    Replace it, while your there, fix up the pipe work and get some better saddling in. Maybe look ing a weather proof cover over the unit as well, might extend expected life span
    Jun 2006
    Quote Originally Posted by HeyBob View Post
    Oop's I posted in wrong section. Thanks...
