Results 1 to 20 of 28
Thread: P66 Variable Speed Controller..
    southeast u.s.
    ... for a Data Aire condenser fan. Will it go bad if the motor and 24v supply for the controller are on different phases?
    southeast u.s.
    Does nobody know or is this question being avoided? I'm kinda new to the forum so I'm not sure how folks operate here.
    FYI, I'm a newbie here, not to the field
    Jun 2006
    New Jersey
    Quote Originally Posted by mortatort View Post
    They are very specific in their instructions that they have to be in phase. Why I don't know? I just do it.
    Ontario Canada
    P66 wiring...
    I think it's page six in the instructions that says the 24 volt supply to the P66 must be on the same 2 legs as the motor itself. Otherwise, it works poorly or not at all. Easy fix. Usually it doesn't kill the P66, just prevents correct operation.
    D.
    Charm City--the city that bleeds
    Patience, Grasshopper. I third the motion forwarded by the previous two associates.
    Nike... just do it.
    It's great to be alive and pumping oxygen!
    SouthEastern Virginia
    I've never seen one wired up wrong to be able to tell you either way. Did the P-66 fail or the motor?
    It might get loud!
    Nov 2002
    NJ - WORK IN NYC AREA
    Cool
    No, the 24 volts doesn't have to bee on the same phase. The reason this is done is to prolong the low voltage circuitry in the control. If the trans is on the same phase, the dc circuits will only be powered when the condensor fan calls.
    If its on another and that phase is live when the power is on to the unit, the dc circuit will always have power.
    The factory also recommends a seperate trans. Some units that come with a P66 already installed, usually don't put in the second trans. to save money. Thus keeping the circuity live. They will use the same trans that powers the stat and other contactors.
    "My hands are for sale"
    Mr. HVAC I think you may be wrong. I have seen them wired to different phases and it will cause the fan to stop when it gets to the high end of the P66 controller range. Not sure why it does it but I have seen it with my own eyes. it needs to be wired exactly as the diagram shows using the same phase of power.
    southeast u.s.
    Quote Originally Posted by duke of earl View Post
    The P66 failed. Actually a couple of them have. I can't find any other reason other than the phasing. I think what happen was someone changed out the var. motor at some point and just wired it back up on a different leg.
    Nov 2002
    Hmm
    FIX,
    I don't doubt what you said about high end failure, but I have never come accross this problem yet? Have used many of them over the years.
    Only had a problem if motor amp exceeded controller.
    Ontario Canada
    P66 failures from heat...
    I've had some Carrier MotoMasters ( a related product) fail from heat and low voltage. The aluminum slab on the back has to be ventilated. I'll sometimes drill a hole in the condenser box to allow air to be sucked over the cooling fins, it doesn't take much to keep them happy.
    D.
    Rapid City, SD
    I've had 3 of those fail. All 3 started leaking freezone out of the control box and made a nice oily mess.
    Maybe I didn't have the refrigerant on the same phase? lol
    Jan 2011
    We'll take your money Ct.
    Is a P-66 controller adjustable?
  14. #14
    Dec 2010
    Va
    p 66
    I have not had probs with the phasing, but they are notorious for leaking freon!
  15. #15
    Dec 2010
    Va
    p 66
    The controls throttling range is fixed an can't be ajusted. The operating range press is ajustable. U should not have to ajust it though.
  16. #16
    Dec 2009
    Southern US
    Small hole in the top upper left hand corner with a straight adjustment screw below. You can adjust the fan pressure start point.
    Usually they are installed in the control cabinet so its hard to access the hole and I have had to unbolt the controller and lean the top out more than once.
    I'm good at making things cold...You can ask my first two wives!
  17. #17
    Southeastern Pa
    The other thing you must watch out for:
    when replacing a motor or cap, any mistake in wiring, particularly the cap wires, will let the smoke out of the P66 board.
    I usually don't adjust them. They work right out of the box.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  18. #18
    Dec 2010
    Va
    10-4 I second that!!!!!!!
  19. #19
    Dec 2009
    Southern US
    I agree but unfortunatley not everyone else does. Hence my previous post on where the adjustment screw is!
  20. #20
    Jan 2011
    Thanks!
    Thank you all for the inputs.
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
