Results 1 to 13 of 21
    Jun 2009
    Lightbulb New 15 SEER Carrier HEAT PUMP
    I am looking into a new Carrier 5 TON 15 seer heat pump/ variable speed air handler that will qualify for the new $1500 Stimulus Plan. Does anyone know if there is a Carrier 16 seer with a variable speed air handler that will qualify and if so, about how much more should it cost? I KNOW ONLY THEIR 'PERFORMANCE SERIES WILL QUALIFY'. Also, I absolutely need humidity control. Will these units help? Do I need to use a thermostat with humidity control on it......does carrier provide one?
    Thanks.........
    Ohio
    Quote Originally Posted by vaderviper View Post
    Thanks.........
    Yes, yes, yes, yes......and yes.......
    Why does it have to be Carrier?? Buy an installing company....not the equipment....
    Equipment is equipment.....just find someone who knows what they are doing to put it in.....
    Anything 15 seer or above in a heat pump will qualify.....
    I need a new signature.....
    You'll have a hard time finding a 5 ton A/C that qualifies for the tax credit.
    May 2009
    So Cal
    Carrier 5 ton systems that qualify:
    ARI# 3344656
    25HCB561A30
    FX4CN(B,F)060
    ARI# 3344695
    25HCB561A30
    FV4BNB006
    ARI# 3286464
    25HBB461(A,W)32
    FX4CN(B,F)060
    Jun 2009
    Smile 5 ton heat pump
    I Bend Metal.........thank you for your reply. I will indeed check into other brands......just used to having Carrier and lucky to have no problems. I am aware that proper installation of the system is very important as well..................again.........thanks!
    As far as humidity concern, the Carrrier performance series system uses the infinity control that also controls humidity.
    Jun 2009
    Ft. Lauderdale, FL
    I am also in the same market. I need to replace a 5 ton A/C in South Florida. Don't need the heat, but the heat pump was recommended so I get the tax credit. Amana has two 5 ton systems: ARI# 923196 (1 stage) and 1291850 (2 stage). My contractor said it will be cheaper after the tax credit than replacing with a decent 5 ton A/C. So you can compare those Amana with your Carrier.
    DC Metro Area (MD)
    Also, Lennox XP14-060-230 and CBX27UH-060-230 is a qualifying match.
    Humidity control is a big thing for you in FL. However, for the 5 ton matchups from Carrier and this one above from Lennox posted, neither qualify with variable speed air handler (only the single-speed high-efficiency blowers), so you lose the ability to control humidity using variable speed technology.
    Have a load calc done on the home. There is a chance that the 5 ton you have now is oversized and a 4 ton would work. Did the old 5 ton short cycle and not control humidity well?
    Quote Originally Posted by I_bend_metal View Post
    If it's all about the install,how do you suggest a consumer find the best ,or at the least a very good installer?
    Quote Originally Posted by letitride View Post
    So does the Comfort Series,not as quite as the Performance,or as t.
    Ohio
    16K posts Dash and you're yankin my chain for something like this.......
    Let's see....BBB, Angie's List, talk to people, past experiences, who do you trust, who have you dealt with before.....I can go on and on.....
    Equipment is equipment.....infinity, evolution, IAQ stat, everyone is packaging up the same things over and over and calling them what they want.....
    You absolutely get what you pay for in this industry.....the OP was asking about Carrier....they make a fine system....so does Bryant, Amana, Lennox, Armstrong, Concord, Comfort Maker, Trane, American Standard......etc...
    The fact is, I can take an infinity system and make it run worse than a 30 year old drum.....
    I thought we all agreed on this.....
    DC Metro Area (MD)
    Find a Carrier FAD.
    Ohio
    Find a Carrier FAD.
    And I would have expected better out of you too......
