Results 1 to 9 of 9
Thread: btu
    Maryland
    btu
    what is the max btu rating for gas fireplaces?
    Maryland
    Is a yellow flame ok on a gas fireplace burner?
    Maryland
    Should my chimney be cleaned before I install a gas fireplace?
    Maryland
    can flexable gasline be run into a wood burning fireplace to be connected to a gas burner?
    May 2005
    Madison, WI
    1, There is no definitive max I know. I have seen gas logs with a BTU input as high as 120,000.
    2, The engineers are going for a yellow flame, so it looks like a real fire.
    3, Yes, and inspected.
    4, Possibly, need a pro to verify and install.
    Bottom line - you need to consult a local pro.
    I think Peterson had a display vented gas fireplace a one of the hearth conventions that was a million btus. I don't think my wallet could support that burner though.
    Some are designed to have yellow flames while burning properly, but others, a yellow flame is a sign that there is a problem.
    I second jtp's answers. You will need a professional to get a permit to run the gas line and install the gas logs.
    Gas fireplaces are not for the DIYer and bad things happen when improperly installed.
    Call a pro, the life you save may be your own !!!!
    Mar 2009
    Michigan
    Confused
    Your question is too vague. There is a big difference between gas log and gas fireplace. Which is it?
    Apr 2002
    You can get a pretty big & exciting fire if you want:
    http://www.youtube.com/watch?v=9jnGs...eature=related
    I hate mushrooms, but the mushroom fireball at the end was kewl !!!!!!
