Results 1 to 13 of 14
    Calgary AB
    No service valve
    I've hooked up my highside of the reciever and there is a valve for my service wrench but on the lowside of the compressor i have now service valve what do i do.
    Apr 2009
    Australia
    Why are you needing to put on your gauges for, I ask because if it's to repair the unit you may be better off using a bullet piercing but you will need to weld it up after your done. Is there a Lp safety with packed angle valve you can tee off. Realy hard to help when you can't see it, I would be pretty confiedent that there would be somewhere you could atatch.
    Calgary AB
    im trying to figure out how much charge is in the system.I Have a service valve but no way to turn it on or off
    Calgary AB
    I feel retarded i wish i had somebody to cal
    Apr 2009
    Australia
    Quote Originally Posted by nick982002 View Post
    I feel retarded i wish i had somebody tocall
    Seems like you need to relax walk away have a coffee, and come back with a clear head and approach it like a pro. Think about the basics, don't panic it's only work
    Calgary AB
    Im no realising the old saying i got from a journeymen "If you dont use it you lose it"
    What type of unit is this? Did you look at the evap for a schraeder?
    California
    you have a receiver, pump it down...add a low side port.
    Winter Haven, FL
    There might be a port at the evaporator outlet.
    Winter Haven, FL
    Dont feel bad, we have all been there in one way or another. Sometimes the best thing to do is to walk away from the unit and not think about it for a few mins. Come back with a clear head and look at the problem from a different angle. If you get down on yourself, you are going to have a much harder time. No one is born knowing this stuff. Its a combination of training and experience. The more you do both, the better you will be.
    Nov 2005
    Haymarket VA
    just leave job best choice
    some time i do grab six pack and enjoy
    Winter Haven, FL
    Quote Originally Posted by sarpanch2001 View Post
    So just walk away from your problems and go drinking?
    You may have some issues that need to be addressed.
    Calgary AB
    It's a modified Copland chiller package a Frankenstein i call it. I have 4 i have to do and this is the only one were i cant back seed my service valve which is really annoying.I figured out later after i hooked up my gauges my low side was like 120 and my high side was sitting around 400.All my boss wanted to know was how much of a charge was in it but it seems like there are bigger problems.
