Page 3 of 3 FirstFirst 123
Results 27 to 31 of 31
  1. #27
    No I don't, that was the previous company I worked for. I can try and find the Whirlpool number for you, it is cheaper to order them thru them.
    I only have to make it work till I retire.
  2. #28
    Jul 2000
    Guayaquil EC
    This site has a ton of info on the little Whirpool icemakers, including restringing kits. Don't know if the parts are the same as the larger machines, but perhaps it will help:
    http://www.truetex.com/icemachine.htm
    Check out Icemeister's Back Room
    Read My Latest Rambling:
    What Are The Correct Pressures?
    ...and a new calculator:
    Nitrogen Pressure Calculator
  3. #29
    Aug 2010
    Thank you Madhat and Icemeister. The problem is those grids won't work for the larger machines as the ice slabs are for cutting grids that are 19" x 21".
    Mike
  4. #30
    Jun 2012
    Northern NV
    Man, I have not thought about one of these for a long time! Was the first IM I had the chance to work on. Had water cooled condenser and would not harvest. Bad condenser water valve. Fun to watch them work and so easy to clean. One tech said he kicked the voltage up from the (i think) 5 volts to 12 volts and made it really chew through the slabs.
    Before it dies and /or gets scrapped, you should do a you tube video of it in operation for posterity. I wish I had vids on some of the old stuff I had worked on to show my students.
  5. #31
    Jun 2006
    That ice machine looks like a subzero mod 506. I have seen that same style ice machine with a couple different brand names.Subzero still make that cutter grid.
