Results 1 to 13 of 33
    May 2009
    Up State S.C.
    Carrier Proposal
    Live in the upstate of So. Carolina. Around Clemson
    Home is around 2,200 Sq. Ft.
    Insulation and ducks OK.
    Can not find this system on AHRI site. (going to put in another return)
    Old AC is 3.5 tons
    Infinity 25HNA636A3
    Coils CNPVP4824ATA
    Furnace 58MVB040-14-1
    Help finding SEER - HSPF - EER
    Do Ya'll think this is a good system.
    DC Metro Area (MD)
    11.5 EER, 8.6 HSPF, 15.5 SEER. I did not find this on AHRI either--had to look at Carrier's performance data table. Carrier makes a nice system. Hopefully you're getting the Infinity controller. Given the efficiency of the furnace, you'll qualify for the tax credit (30% up to $1500).
    May 2009
    Up State S.C.
    Thanks Ryan,
    Yes I am getting the Infinity controller.
    I thought I read one time that you had said something about the small furnance - is it too small.
    DC Metro Area (MD)
    Furnace sizing is determined by calculating your home's heat loss. You can ask your dealer about this and how he arrived at the sizing. That's a 40k furnace only but it can deliver the airflow needed for the 3 ton unit (-14 = 1400 cfm). I'm not sure why it isn't listed on AHRI.
    May 2009
    Up State S.C.
    Thanks Ryan - now I know what the 14 means - I did see 14s' and 20s' = 2000
    May 2009
    Up State S.C.
    Ryan or anybody
    Would a 58MVC 60 -14 change any of my ratings.
    Apr 2009
    Central New Jersey
    Infinity 25HNA636A3
    Coils CNPVP4824ATA
    The 58MVB040-14 is a 17 inch wide furnace, but the CNPVP4824 is a 24 inch wide coil. Why is the contractor proposing this? I have a CNPVP4821 (21 inch wide) on top of one of my 58MVC60-14 (17 inch) furnaces. The contractor made a transition duct between the two. You could also use the CNPVP3617 coil which is 17 inches wide and requires no transition (I have this set up also).
    DC Metro Area (MD)
    Mike,
    The 040-14 is 24" wide, and the 060-14 is 17" wide. No issue with coil width here.
    M&B,
    25HNA636A30
    CNPVP3617ATA
    58MVC060-14
    11.5 EER, 15 SEER, 8.4 HSPF
    It does qualify for the tax credit because the furnace is 95% AFUE (as long as its in the upflow position which I assume it is).
    May 2009
    Up State S.C.
    Thanks Mike,
    I do not know yet and as you can see Rayn did not say anything about the width. You are saying the coil is wider than the furnance.
    May 2009
    Up State S.C.
    Is there a better coil that will not lower my ratings and fit?
    DC Metro Area (MD)
    Quote Originally Posted by M&B View Post
    For which setup? For the setup I listed with the 58MVC060, 17" is the width you want to be flush with the furnace, so that is the best coil option. For the 58MVB040, 24" is the width you want and so I believe they quoted you the best coil (4 ton) there.
    May 2009
    Up State S.C.
    Ok, I am a little slow - been looking at a lot of #'s. I see the coil # now.
    Thanks Ryan
    DC Metro Area (MD)
    Since you have a heat pump for primary heat source, really no need for the 3 heating stages of the 58MVC. The 58MVB should be more than sufficient with 2 stages.
