Results 1 to 13 of 14
    May 2009
    Carrier model number cross reference?
    Does anyone know where I can find a listing of carrier model numbers or know how they break down?
    Specifically, I am trying to find out information about:
    24ABB336A310
    I cannot find it anywhere on their site.
    Thanks!
    PA/DE area
    Thumbs up
    It is a 13 SEER 410a PURON a/c with 5 years parts on it
    It's NOT the BRAND,it's the company that installs it!!!!!
    DC Metro Area (MD)
    Post
    Base/builder grade. 13 SEER, R-410A. No high or low pressure switches, no coil guard (both good to have for protection). 5-year warranty on all parts.
    The 24ACB336A300 has high and low pressure switches and louvered coil guard standard. 10-year warranty on compressor, 5 years on all other parts.
    May 2009
    3 ton, correct?
    DC Metro Area (MD)
    Yes. 36 = 3 ton.
    May 2009
    SE Michigan
    Quote Originally Posted by adamt56 View Post
    3 ton, correct?
    Why, ya gunna change it out with a gooman or coleman?
    “Now the freaks are on television, the freaks are in the movies. And it’s no longer the sideshow, it’s the whole show. The colorful circus and the clowns and the elephants, for all intents and purposes, are gone, and we’re dealing only with the freaks.” - Jonathan Winters
    May 2009
    It is already installed (8 months old).
    It has been having some problems getting the temperature in the house down to where we like it (73-74 during the day) and seems to run very long cycles at night.
    I just wanted to make sure we got what we paid for . . .
    DC Metro Area (MD)
    You probably want to have the installing company back out to look at it. Could have charge problems, or something else preventing you from cooling effectively. Was the old unit a 3 ton that it replaced? They can come out and take measurements and perform checks. Should be under labor warranty with >1 year old.
    May 2009
    It replaced a 2.5 ton which was undersized.
    One room which has three large windows facing West heats up pretty good during the day. I am in the process of coating those windows with window film so, hopefully, that helps . . .
    DC Metro Area (MD)
    How do you know the 2.5 ton unit was undersized? It could have been inadequate ductwork from the beginning causing poor cooling. And increasing the tonnage therefore didn't help.
    May 2009
    You could be right about the duct work -
    I just listened to what the 3 companies said that came out to give estimates.
    3 ton seems about right though with 1450 sq foot living area, 1954 home w/ no insulation in the walls, single pane windows and one room with a flat roof (no insulation).
    May 2009
    Smile
    Quote Originally Posted by coolwhip View Post
    Maybe, if it can make icicles hang from the ceiling
