Page 4 of 6 FirstFirst 123456 LastLast
Results 40 to 52 of 78
  1. #40
    Jul 2013
    Atlanta
    MC1, TX1, SBC and GX Manuals
    Does anyone have a link to the user/programming manuals for MC1, TX1, SBC and GX?
    Mike
    Quote Originally Posted by davem View Post
    Those types of replacements (Sage to Tridium) go well when you know Auto-Matrix hardware. If you don't know all the attributes that lie underneath the Current Value, or how the controller schedules work, or how the control loops are addressed to correspond with the outputs, you'll end up fighting the controller - so do your homework!!
    And if the Sage is running any programs, make sure you can emulate those functions. Some programs can be emulated simply by linking two objects together (which requires a custom program in the Sage if the points lie on two different PUP networks) - others can be emulated through regular Tridium objects...as sophisticated as SPL is, I've been able to get every SPL program I've run across ported over to Tridium with a minimum of fuss...
    Or keep the Sages - provided you don't lose a hard-drive, those things run incredible amounts of controllers and points with nary a hiccup. But dapper is right on the money - AAM's existing software sucks for trending and alarming, although the graphics can do just about anything you need, as long as that's all you need (although setting schedules is a little kludgy too...).
    It looks like AAM has re-invented the wheel again (their corporate history is all about re-starts, from a software perspective - in less than 20 years, they've used four different GUI's (Mouseview, Spectra, Auto-Pilot, then they finally "discovered" Tridium)) with Aspect being the latest and greatest front-end. If you're not a dealer, then it may not be available to you, so perhaps the Tridium route might be to your liking - but find out if Matrix is going to be supported by AAM for any length of time (or simply buy the PUP driver with a WEBS controller or a JACE (if you have access to the Vykon channel)) - there's no need to rely on AAM to support your front-end of choice, given that their track record shows that they'll forget all about it in 4 or 5 years anyway. To be fair, some of the changes in software platform were as a result of PC technology advances (Mouseview was DOS-based, after all), but they never really developed any of the Windows packages to a fully-functional software suite. Once they finally got to Tridium, several years after forward-thinking people finished the PUP drivers (for the r2 stuff too!), they've moved on again...
    But you'll like the hardware, once you get to know it - like Reaper said, hearty and reliable.
  2. #41
    Jun 2006
    New Jersey
    Quote Originally Posted by snowm0811 View Post
    Mike
    You have mail.
  3. #42
    Aug 2011
    Denver PA
    I could use a copy of that.
    Thanks Ken
  4. #43
    May 2002
    Baton Rouge, Louisiana
    Could I get a copy please
    Quote Originally Posted by MatrixTransform View Post
    very soon it is you that will be pwned
  5. #44
    Hampton Roads, Virginia
    A copy for my library would be appreciated.
    Kevin
    "There is plenty of room at the top because very few people care to travel beyond the average route. And so most of us seem satisfied to remain within the confines of mediocrity." -- Benjamin Nnamdi Azikiwe, first president of Nigeria
    "It's not the customer's job to know what they want." -- Steve Jobs
  6. #45
    Jun 2013
    If possible, could you please send me the link or a copy for our referrence. Your help is appreciated.
    Thank you,
  7. #46
    Jul 2012
    Northern NY
    I also could use a copy. Currently working with a site where I think some TX01 have been wired wrong since day they were installed.
    -Jeremy
  8. #47
    Mar 2012
    AAM SAGE to JACE Integration
    I need Help! I posted this else where, but thought someone within this thread could help.
    Has anyone out there setup a JACE on an American AutoMatrix Network with existing SAGE Units still in operation? I have a customer that has ask for exactly this as Phase I of his upgrade.
    I was able to look at the SAGE Unit using ADAM and confirm that all 4 ports are setup as PUP Networks 9600/8/1/N.
    What setting do I need to change in the SAGE for it to allow the JACE to set on the same network and see the same points?
    I also confirmed that the JACE has 4 network cards all setup with the PUP Drivers.
    Can it be done? I believe it can, just really not familiar with the SAGE Units at all.
    I have tried to contact AAM with no luck so far?
    Thanks for the help.
  9. #48
    Jul 2012
    Northern NY
    From my limited experience you can have 1 master type device on the network, either the JACE or the SAGE but never both. Maybe there is a way to make the JACE act as a slave style device and exist but I am not aware of the setup for that.
    -Jeremy
  10. #49
    By default the Sage & PUP devices do not use token passing but it can be enabled. If setup for token passing then there is no sole master and you could have the Sage and Jace online at the same time. This would be a setting on the PUP driver in the Sage as well as all of the field devices. I am with some AAM people today and will ask them to verify it.
  11. #50
    NC
    Osiyo is pretty sharp on that line.
  12. #51
    Nov 2009
    any chance I could get those reference manuals? Need some more late-night reading material.
  13. #52
    Minnesota
    Quote Originally Posted by BMSdude View Post
    Well .... I've sure as heck never tried to do a replacement of a Sage with a Jace the way you're trying to do it. And I've done a lot of Sage replacements, with Jaces or AspectFT systems.
    Technically a person could do something along the lines of what you suggest, tho I sure as heck don't know WHY you'd want to do it that way.
    Leave the Sage as is, put Jace on a port as an irresponsible peer ... with a non-conflicting network ID ... that way it won't try to seize the token. Put Jace's network ID on Sage's list of peers. Periodically, in accordance with settings you selected, Sage will pass the token to Jace, and allow N number of transactions.
    Pretty much the same procedure you'd use to let any other PUP controller on line and give it the token periodically so it could play Master and send or fetch information.
    <Shrug> Never done it that way. Wouldn't do it that way myself. But it should be quite doable. It'll have lousy results. Both will be really slow in fetching or sending data. Which may or may not have adverse results on overall sysem operation. No way for me to know as I have no details of the system setup, how many controllers are on line for each port, how much of the control routines resides at the field controller level as versus at the Sage level.
    Typically we'd pre-set up a Jace, and just cut over everything at once. Or, if a larger and more complex installation, we'd do one port at a time. Leaving Sage intact. Pre-setup Jace for one port at a time, pull designated port cable from Sage and plug into Jace. Verify everything is working, tweak and adjust as necessary. If it takes more time than we have, i.e. more than an 8 hour day, remove cable from Jace and plug it back into Sage for over night.
    Switching from a Sage to a Jace (or an AspectFT system) isn't just all that complicated as long as one does one's homework and verifies how the existing system really is operating, who's doing what and how, etc.
    A site where I stash some stuff that might be interesting to some folks.
    http://cid-0554c074ec47c396.office.l...e.aspx/.Public
