Results 1 to 13 of 27
05-20-2009, 04:55 PM #1
Member
- May 2009
- Allentown, PA
- 17
Random PC Crash during N2 Serial Tunnel
When connected to a site via serial tunnel, I am getting random PC crashes. The crash is the "Blue Screen of Death" and I must power off to restart the laptop. I have tried this on different laptops and different locations with the same results.
One day I worked on a site and commissioned three different systems all day long without a problem and other times I have tried to download a small program to an FX05 and as soon as I connect, the PC crashes.
Has anyone else had similar a similar experience? Johnson says they have no problem with it (imagine that!). I am using a Dell D830 laptop and a cable modem high speed internet connection. Any pointers would be GREATLY appreciated!
Best Regards,
MrEddySpag
05-20-2009, 07:02 PM #2
Professional Member*
- Mar 2009
- Several Miles from Sane
- 1,409
What OS do you have on the Laptop ? Hopefully not Vista.
If sense were so common everyone would have it !
All opinions expressed are my own. Any advice provided is based on personal experience, generally accepted fact or publicly available information. As such, it is worth exactly what you paid for it, not a penny more not a penny less !!
05-21-2009, 08:24 AM #3
Member
- May 2009
- Allentown, PA
- 17
Windows XP Professional SP3
11-06-2009, 05:21 PM #4
- Jan 2006
- Houston,TX and surrounding areas
- 15
The problem is most likely caused when you click on the X at the top right to close out the fx comm pro.
If so, when done with the comm pro instead click file then either exit or close (i forget which) this has eliminated the problem for me.
let me know.
thanks,
sean
11-06-2009, 08:59 PM #5
Member
- May 2009
- Allentown, PA
- 17
Since my original encounter with this problem, I have found that exiting CommPro seems to give me an IRQ error blue screen. Other times, as I said before, I get a different blue screen while discovering controllers, downloading/commissioning, or just doing nothing. The IRQ error only seems to occur on exit. I will try using the File/Exit instead of the red X and see if it helps the IRQ error. I have also talked to Milwaukee about this again and they have been in contact with Tridium. I questioned the serial tunnel.txt file that refers to version 1.2 and the installed version off of the Workbench CD is 1.1. The .txt file indicated a problem with 128 bit word errors. I have not been able to find this mythical version 1.2 and have had no reponse from Johnson as of yet.
11-06-2009, 09:00 PM #6
Member
- May 2009
- Allentown, PA
- 17
Thanks for your reponse to this aggrivating problem!
11-06-2009, 11:23 PM #7
- Sep 2009
- 141
If you post the core dumps (xp default will generate them) or post the "cryptic" error message shown on the BSD I can either tell you exactly why it crashed or at least point you in the right direction. The core dump file is more helpful and xp by default will generate them so unless you've changed the default settings they'll be there. The error message will only give you the reason it crashed with no information as to why that condition existed in the first place.
Respectfully,
D1G
11-06-2009, 11:30 PM #8
Member
- May 2009
- Allentown, PA
- 17
[IMG]C:/Pix 001.jpg[/IMG]
Guess that didn't work - I have screen shots of each errorLast edited by MrEddySpag; 11-06-2009 at 11:31 PM. Reason: Added comment
11-06-2009, 11:52 PM #9
- Sep 2009
- 141
Last edited by D1G; 11-06-2009 at 11:58 PM. Reason: I'm probably missing something completely obvious.
11-07-2009, 06:38 PM #10
Member
- May 2009
- Allentown, PA
- 17
http://cid-3fe0e5a29d38199a.skydrive.../Pix%20001.jpg
http://cid-3fe0e5a29d38199a.skydrive...A29D38199A!121
Here are the (2) links to the screen error pictures... take a look.
11-07-2009, 08:25 PM #11
- Sep 2009
- 141
Those indicate the device driver is "crashing" (parent directory is normally %WINDIR%\SYSTEM32\DRIVERS\) in both images but in different portions of allocated memory.
There was at one point an issue where if you ran out of virtual memory you could get the same "DRIVER_IRQL_NOT_LESS_OR_EQUAL" and simply increasing the size of your VM would work around it. If your box has been patched in the last couple years I'm almost positive this has been fixed.
Since your issue spans different hardware and your faults are occurring in different sections of allocated memory I would point the finger at your application passing bad code (argument, request, etc..) to the system.
The BSOD screens offer very little insight into the nature of the issue. If you're lucky the offending execution will have produced an event when it occurred before it snowballed into the system crashing. What does Event Viewer have logged?
11-07-2009, 10:06 PM #12
Member
- May 2009
- Allentown, PA
- 17
I cleared the event log and started a serial tunnel connection. I downloded a controller, commissioned, and was just navigating between controllers and then crashed. This looked like an entry that looked like something related. What do you think?
Event Type: Error
Event Source: Serial
Event Category: None
Event ID: 36
Date: 11/7/2009
Time: 9:32:52 PM
User: N/A
Computer: EECI-BRIAN
Description:
While validating that \Device\Serial1 was really a serial port, the contents of the divisor latch register was identical to the interrupt enable and the receive registers. The device is assumed not to be a serial port and will be deleted.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 00 00 08 00 02 00 56 00 ......V.
0008: 00 00 00 00 24 00 06 c0 ....$..À
0010: 3e 00 00 00 00 00 00 00 >.......
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
0028: e8 02 00 00 00 00 00 00 è.......
11-07-2009, 10:07 PM #13
Member
- May 2009
- Allentown, PA
- 17
The link to Microsoft's knowledge base has no further information.
