Results 14 to 26 of 33
    Sounds like flood back
    You need to take the EPA 608 test and pass it to do what you want.
    get a study Guide and study up then take the test you need a min of level II to work on a split systems and/or over 5 pounds
    Change your filter.
    Otherwise, call someone who knows until you know.
    Get a good tech out there and hang with them ask question and then read up on the what and why. Your Not Legal to be working with the AC yet and you aren't ready to be YET.
    But It will come in time, Like your eagerness to learn.
    Good luck in school
    Apr 2009
    R.O.T.
    Quote Originally Posted by ascj View Post
    A over charged system can frost a suction line. Your feeling, is just that a feeling. Leave to it some one else, until it's not a feeling anymore.
    Can you help me understand how an overcharged system can frost a suction line?
    Quote Originally Posted by Edwin73 View Post
    With a fixed metering device, an overcharge will lead to low superheat.
    Jun 2006
    New Jersey
    Or any metering device with low airflow and someone added gas to try to fix the system. If your suction line gets to 32 degrees or below it will freeze.
    Apr 2009
    R.O.T.
    True, but a low superheat does not mean that the line temp will be below 32degrees F.
    Apr 2009
    R.O.T.
    32 degrees or below will freeze, but overcharging will raise the saturation temp.
    It doesn't HAVE to freeze, it just MIGHT freeze.
    Jun 2006
    New Jersey
    You basing this on proper air flow. jpsmith1cm and I are pointing out that, most guys see low pressures and/or frost and add gas and over charge the unit. So yes a overcharged unit can have a frozen suction.
    Apr 2009
    R.O.T.
    Even with low airflow, a system can be overcharged to the point where it will not freeze. I've recovered many a lb of refrigerant out of a grossly overcharged system that was not freezing until the saturation temp dropped below 32 degrees F.
    Jun 2006
    New Jersey
    Did I say all?
    Apr 2009
    R.O.T.
    Did I say all?
    Don't get me wrong, I'm not questioning y'alls ability or anything. I really enjoy talking about the thermodynamic properties of refrigerant, and I'm always open to learning something new. I guess I just misunderstood.
