    Oct 2001
    Rochester Michigan
    Fan speed settings Bryant 90t 352mav
    hello
    I have a Bryant 90t 352mav furnace & I can't find the user's manual. I'd like to lower the fan speed to increase dehumidification from the ac. Would someone be kind enough to provide a table of the settings & a diagram of where to find the switch block on the circuit board ?
    thanks
    mark
    Oct 2001
    Rochester Michigan
    Bump.... Waiting for a reply .
    Bay Area, CA
    I dont believe you will find any answers in this forum, something about no diy. If you slow the fan down and your system is not properly tested and setup with a slower fan speed you will do more harm then good.
    Global Warming or: None like it hot
    No pleasure, no rapture, no exquisite sin greater... than central air. -Dogma
    Alabama
    call a pro. you wont get the response you want on here!!!
    You're only as good as your customer will allow you to be.........If they want junk, sell them junk, but make your junk look neat!!!
