Results 1 to 7 of 7
    Hmm 40 degree suction line @ compressor?
    40 degree suction line @ the compressor-is this ok for an R-22 unit on a 65 degree day.pressure is 60 on the low side 160 high side, superheat is 6 degrees-note my heat load is low could this charge still be ok even if i dont have a superheat near 15/20 degrees-also this is a fixed orifice coil.
    Winter Haven, FL
    i dont know
    Sorry, this is not a DIY site. So we are not allowed to give out advise of this nature.
    Since answering your question in the open Residential Forums would be posting instruction for DIYers that may read this post later.
    If your in the trade, get your post count up to 15, and apply for Pro Membership.
    Then use this link Apply for Pro Membership
    Once accepted, you have access to the pro tech forums. Where you can ask and get answers to technical questions.
    Plus, you also have access to the Pro Educational Forums.
    All of it is free.
    Mar 2009
    check your superheat
    Toledo, Ohio, United States
    Twilli whats superheat? Is it on your thermostat somewhere?
    No Heat No Cool You need Action Fast
    Burleson, Texas
    Quote Originally Posted by twilli3967 View Post
    I thought "superheat" was your girlfriend's name????
