    Rheem Unit - HPC Reset - Why?
    What is the High Pressure Control reset button for on the outside unit and what causes it to need to be reset - A/C was out last night - turned it off overnight - turned on in morning - still blowing warm - went out back and saw fan on condenser unit not moving - saw reset switch - pressed it and it started up and is now blowing cold inside - so - what caused the need for a reset?
    DC Metro area
    It's there to protect the compressor. If it has a high pressure problems, needs service.
    Lancaster PA
    If last night was the first time you tried to use your unit in cooling mode.
    Check your air filter.
    South Mississippi on the Golden Gulf Coast. 100 degree heat and 90% pluss humidty.
    possible cloged/dirty cond. coil. System needs to be properly checked out , cleaned and serviced. Just pushing reset will cause damage to system.
    Apr 2009
    R.O.T.
    If It's a heat pump, this might be the case. If it's a conventional a/c unit, a dirty air filter will not make the HPC trip out.
    There is a number of things that could cause the HPC to trip, better call a pro fer service.
    Here and there
    Post model#'s in and out
