Results 1 to 10 of 10
    May 2009
    Replacing HVAC system: Tax Credit
    Will a trane XV80 2 stage variable speed gas furnance with the 3 ton Trane XL 15i Heat Pump qualify for the new engery tax credits?
    I have been told that it will but I need to confirm.
    Need to know exact model # of heat pump, coil and furnace.
    May 2009
    Furnace: Model # TUD080R9V3K
    Heat Pump: Model # 4TWX5036A1000A
    Coil: Model # 4TXC8036BC3HCA
    Mar 2006
    The South
    No
    1384221 Active Systems XL15I WEATHERTRON TRANE 4TWX5036A1 4TXCB036BC3 *UD080R9V3 34000 11.50 13.75 36600 8.50 23600 1
    short on EER and SEER
    May 2009
    Without tax credit the system is about the same price as a 95% efficient furnance Carrier and American Standard quoted with 15 seer heat pump. You do get the tax credit.
    Worried about the Trane dealer telling me the system did qualify.
    Jun 2007
    The Twilight Zone
    Quote Originally Posted by redbug View Post
    The 3-ton XL15i qualifies for the Fed Tax Credit if an Aspen coil is used (model# C*48D44) and the furnace is Trane Model# *UD1B080A9HB. Not sure of the difference between the furnaces.
    That match-up is AHRI Reference# 3376609. 36,000 btu cooling, 15.5 SEER, 12.5 EER, 37,200 btu heating at 47F, 8.8 HSPF.
    Take care.
    May 2009
    OK,
    Thanks for the info.
    I am using the furnance for backup heat only.
    The heat pump will do most of the work.
    Jun 2007
    The Twilight Zone
    OK,
    The 37,200 btu heating is slightly above the nominal 3-ton size of 36,000 btu, so you're getting a good bang for your buck with the heat output using a 3rd party coil. I would want to know if that 3rd party coil gets the same warranty as a Trane evap coil.
    Take care.
    Apr 2005
    N. E. Missouri
    Why do people keep calling it a rebate?
    It is a credit. There's a HUGE difference in those two words.
    Jun 2007
    The Twilight Zone
    Quote Originally Posted by mrs reb77 View Post
    Typo. I fixed it.
