Results 14 to 18 of 18
    Aug 2005
    Pa
    Quote Originally Posted by amd View Post
    Fixed
    Odd how low charge could be misdiagnosed as a bad txv.
    If there's a leak the problem will recur - I would get it repaired. Adding refridgerant isn't part of normal maintenance.
    A restricted txv may show up as low charge is he's a low side only tech.
    May 2009
    Quote Originally Posted by rooftop tech View Post
    What do you mean? Can you explain please? Is this a problem?
    May 2009
    [QUOTE
    If there's a leak the problem will recur - I would get it repaired. Adding refridgerant isn't part of normal maintenance.[/QUOTE]
    I really think first tech misguided me and wanted to sell new system. 2nd Tech did replace valve on the HOT side of the pipe. My machine is working great since the repair (30 hours).
    Is there any sign I should look for?
    Aug 2005
    Pa
    A restricted txv typically will give low pressure on the low side and high pressure on the high side. Alot of techs don't bother with a high side gauge for whatever reason. I'm as guilty as the next guy I"ll admit. At any rate if he came out and the suction pressure was at 45 instead of 75.....he adds refrigerant until it's where he wanted it and everyone is happy and figures it's fixed. Everyone is always quick to question the first tech at the job but no one seems to ever question the 2nd guy. I've made very simple diagnosis in the past and had a 2nd opinion come up with something totally off the wall. I've also found that if the customer is calling for a 2nd opinion there is a reason and they'll believe just about anything they're told at this fragile time.
    I don't know
    Yup I'm aware of that - no good tech would diagnose a system based on pressures alone.
    For a refrigerant leak: deteriorating performance over time, oil at the site of the leak (you won't spot this if the leak is inaccessible), high operating costs.
    economic collapse is a certainty. debt based fiat currency monetary systems can never continue indefinitely because they require continuous creation of new debt to service the existing debt. in the absence of economical growth (which is always predicated on increased resource extraction rather than capital alone), this leads to massive inflation which destroys the currency.
    your leaders can't fix this - they're corrupt and only exist to enrich themselves and their corporate friends.
