Results 1 to 13 of 22
    May 2009
    1 stage vs 2 stage unit, (houston area)
    folks need a little help
    1. what is the diffence btween a 1 stage and a 2 stage unit.
    2. which one would benefit better in houston home
    3. any other item that is must need for houston weather
    and yes i am in the mkt for a new units, compressr is abt to kick the bucket (5ton) in one of the units
    house built 1999
    city houston
    3200 sq ft
    electric rate .117
    carrier 5 ton and 3 ton
    guess seer was 10 now 7 mayb
    thinkin of replacing something with along the lines 14-16 seer (cuz cost to saving ratio) is a lost cause never recoupe the cost of the units to see actually saving
    also could anyone recommend hvac for west houston
    Cuctomers here in humid Florida love the two stage units,as they do a great job of reducing the indoor humidity level.
    They can run at reduced cfms(air flow),to remove more humidity,plus in low stage the run longer,further reducing the humidity.Longer run,is in low stage so it costs less then high stage,per hour.
    Great controls like Carrier Infinity are available to reduce humidity,so regardless of brand be sure to get the best control they have to control/reduce humidity.
    May 2009
    ok thks, nxt question is thr a min level one should look for in a control, meaning how can i tell one control from another
    If your getting a 2 stage that isn't a Carrier Infinity.
    Then the Honeywell IAQ thermostat.
    4H: Hot, Humid Houston H.O.
    There are two companies I have worked with as a customer, that serve the West Houston area. One is a large company named Absolute Comfort. Another is a one man business called Addicks Air and Heat. There is also a guy on this board named Al Fowler (Aire-Serv of W. Houston?) who seems to have a lot of knowledge based on his posts.
    I am glad I got a 2-stage system but if money were tighter would be fine with one of the higher efficiency 1-stage systems. In any case would get a variable speed air handler to enable some of the better approaches to humidity control.
    Hope this helps -- Pstu
    Apr 2009
    R.O.T.
    Two stage is the way to go. Thats what I recommend to all my customers. A two stage unit is great for dehumidification in Houston. The only system better in my opinion would be a Frigidaire IQ Drive.
    May 2009
    hey thks
    any other TIPS u can pass along to help whn i get these proposals
    May 2009
    buying new HVAC
    I live in Kansas city,Mo I need to get new system. the a-coil has been leaking Which is better Trane, carrier, Heil or amana. Help my head is spinning
    Quote Originally Posted by evahusted77 View Post
    I would be more concerned about,
    Installation-Warranty-Price-Manufacture, in that order, if price is not a concern, well then, Installation-Warranty-Manufacture.
    May 2009
    another question what r is done to determine a load calculation
    May 2009
    next how much might it run me to have one of these load calculation done by a outside company
    or is this done by the hvac company
    We don't talk prices here, please read the rules.
    Your HVAC contractor should be able to do a load calc.
    If not, keep calling until you find one that does them.
