    Austin
    York H2RC030S06A
    My son bought a small house (around 1100 sq ft.) last fall and had everything checked out by a inspector that was recommended by his lender. Everything checked out fine. Since it's started getting warmer, the air conditioner has been running and seems to run a long time before shutting off. How can I tell what tonnage the unit is? The serial # is WFMM086607
    Also, one of the plaques near the evaporator core has both r-12 and 134 listed as usable. How can we tell which one is being used?
    Would just like to have this info before he calls a tech.
    Thanks,
    Wayne
    Its a 2.5 ton.
    Soze is in the model number(030).
    It doesn't use either of those refrigerants.
    Austin
    Thanks for the reply...would the refrigerant be r410 or r22? Also, can you give me the approx age of the unit?
    Thanks again,
    Should be a 12 SEER, 2003.
    Refrigerant type should be imprinted on teh unit, should be an R22.
    Austin
    Thanks again....going to have a tech look at it next week.
    Wayne
