Results 1 to 13 of 17
    Dec 2008
    A/C doesn't turn on
    Problem: Honeywell wall thermostat (7 years old) was turning central A/C on and off perfectly as recently as 1 hour ago. However, suddenly the following is happening:
    Switches set to COOL and AUTO, nothing happens (no A/C, no fan) even though temp is set to 60 and room temp is 80.
    Switches set to OFF and FAN ON, the fan comes on.
    Switches set to COOL and FAN ON, fan comes on but no A/C.
    Any thoughts why the COOL/AUTO combo suddenly doesn't work?
    Thanks.
    The A/C is broke.
    Time to have a service tech check it out for you.
    Sorry, this is not a DIY site. So we are not allowed to give out DIY advise.
    Please read Site Rules Thank you.
    Hmmmmmmmmmmm ive never heard of anything like it before. Wonder what it could be?
    May 2002
    Houston Texas
    Well it could be a bad thermostat, brokrn wire, bad control board, bad relay. As Beenthere said call a pro before you cost yourself more money!!
    May 2009
    Earth
    Could be the Proton Modulator is going bad, that is very common on these units.
    Quote Originally Posted by 2001 View Post
    or the flux capacitator
    Apr 2009
    R.O.T.
    What about the kanooter valve?
    Apr 2009
    Talking
    There are some funny people here.
    In all serousness as beenthere said it is time to call a tech. It could be something simple as a loose connection or something a little more technical, in any case, you should have a tech check it out, as well as check out the system as a whole, before it gets really hot and humid.
    A properly maintaned unit will last a long time, pre season service check is cheap compared to a middle of a hot humid summer no cooling ( both in price and family harmony).
    Jim
    Thanks guys i needed that, was hoping someone would pile on.
    It really could be anything so unfortunately you will have to call someone, even if we could help there are just to many things and we cant have you burning your house down.
    Delaware
    Something you could check as a homeowner (You should be checking) is to see if the drain pan is full of water. You could have a safety switch on the system to prevent damage to the home if the drain becomes clogged. This is good info to tell the service tech.
    Always here
    right! check the flapper valve bearings
    Apr 2005
    N. E. Missouri
    No, no, no. The flapper valve bearings wouldn't allow the fan to blow. Sounds like the heat removing conditionator.
    You have to be careful, some of those Honeywall wall thermostats had bad kernalator valves.
    The floor mount thermostats were non-hibachi units, couldn't ever trust them after about
    7 years.
