Results 1 to 13 of 23
    Somewhere in the world.
    Hope you got a good explaination for this one !
    Was asked to go check out damper section on York solution unit and this what I found , Lucy you got some explaining to do !
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    Madison, Wisconsin
    Umm fealing like an idiot, all I am seeing is a well cleaned area with dirty filters behind it? What is wrong, I am guessing there is something missing?
    I r the king of the world!...or at least I get to stand on the roof and look down on the rest of yall
    Jan 2005
    steeler nation
    i see imploded ductwork in your future.
    IV IV IX
    use your head for something other than a hat rack.......Gerry
    We have freedom because somebody fought for it.
    We keep it because we are willing to fight for it.
    We lose it because we are not willing to fight for it.
    Western MA.
    Not really sure what I`m looking at ,but are those dampers supposed to be vertical instead of leaning?
    I love overtime I just hate working for it.
    Quote Originally Posted by Wheelbaron View Post
    Looks more than dirty filters someone decided to start the fan before proving damper status postion then allowed the fans to start VFD's end result calasped return air section who is to blame I will give you one guess ?
    TIP-O-TX
    Ricky's spelling
    Quote Originally Posted by york56 View Post
    It's Luthi jew got som splaining to doooo!
    Mar 2009
    So if the dampers fail this is the result? Seems poorly constructed.
    I don't care who manufactures it if you start a fan without knowing what the dampers are doing and if there is enough force within that fan this will be the end result I myself have seen entire wall structures torn down due to this problem. And I am not just talking about rooftop or indoor units sometimes entire penthouse structures are the plenums for supply and return ducts.
    Jan 2005
    steeler nation
    i've seen the amazing force of large fans a few times. entire sections of outside air duct flattened taking electrical and piping with it.
    freaking control guys
    IV IV IX
    Madison, Wisconsin
    OH lol I see it now
    Static and null switches if set properly would have more than likely stopped this from even happening on both supply and return fans. And don't look at me cause I didn't start it up , because thats the first thing I set up , there are 3 critical componants you should set static , freeze , fire
    Jan 2003
    Add, smoke dampers in the open position, plastic removed from supplies and returns, and check operation of the economizer (will the fans off)....then start the fans with your finger on the kill switch.
    MD Coast
    That first picture...The linkage looks, um... creative.
