Results 27 to 39 of 50
  1. #27
    Float'N Vally, MS
    Quote Originally Posted by Lee Adams View Post
    Hi
    Im just curious at what the trending data proved I mean what fluxuations do you look for? Xvlv does that mean same as TXV or TEV?
    Im trying to justify buying a digital outfit and your case sounds like a good reason.
    That's correct TXV action along with SC & SH. I also have the temp sensor(s) so we can also trend outside air and/or inside air all on the same "graph". I picked up the 556 and the 435 set for performance testing. Pretty pricey but you can document everything on paper with accuracy.
    My Testo's are used daily. But this is mostly a low end area and performance is secondary to price in most H.O.'s minds.
    Now this being said the Digi-Cool units are very impressive! I tested a set for a while and found them to be very rugged and accurate. Doug has put his heart and soul into this product and it shows!
    Life is too short, Behappy!
    TFMM
  2. #28
    Akron
    Quote Originally Posted by Pneuma View Post
    I'm pretty set on the digi-cool 1250 since it doesn't seem like the print out feature of the 560 is really enough to keep me from having to fill out an inspection log sheet anyway. I don't need data logging in the true sense of the term. Now all I have to do is get the book keeper to approve dropping the money on that and the Testo 510! I hope I can get a discount if I buy both...true-tech can you hook me up? Luckily tomorrow is bookkeepers day...err Mothers day and maybe I can catch her in a good mood and she'll sign off on it!
    From Bill Spohn @ TTT Use "HVAC-Talk" in the coupon code box when requested for 6% off your purchase.
    (case sensitive)
    This will work for anyone following this thread for the next 10 days
    JLB,
  3. #29
    Float'N Vally, MS
    Quote Originally Posted by jim bergmann View Post
    (case sensitive)
    WoW a TESTO guy giving away a coupon for a Digi-Cool product.
    TFMM
  4. #30
    Washington, DC
    (case sensitive)
    Jim, I just placed my order for the digi-cool 1250. It's always great to get a discount, thanks true-tech! I can't wait to try it out.
  5. #31
    Jun 2005
    Near Chicago, IL
    Quote Originally Posted by behappy View Post
    If you are working in a price conscious area, then how is the cost of the equipment justified?
    Is that much time saved?
  6. #32
    Oct 2007
    ATLANTA
    Confused
    (case sensitive)
    Sorry to be stupid here but is the discount for TESTO products? I have no clue who Bill Spohn or TTT is? I even did a search for both and could find nothing.
  7. #33
    Washington, DC
    http://www.trutechtools.com/cart/ind...ain_page=index it's an excellent HVAC tool site. Bill works there...
  8. #34
    (case sensitive)
    hey Jim, my 605-H2 is about a year old or so now, and the DB temp is not reading what my calibrated dual input temp meter is reading. is there a way i can adjust it myself?
  9. #35
    Akron
    Not that I know of, but I would check it against a known source under controlled conditions before I questioned it. Usually they work or do not. They are not a thermocouple they are thermistors. K-type stuff looses its calibration and repeatability over time. I have some that are over 8 years old that are still perfect.
    JLB,
  10. #36
    will check it again
    would it mess it up if i gave it an ice water bath?
  11. #37
    Float'N Vally, MS
    Quote Originally Posted by neophytes serendipity View Post
    When it comes to Testo or Digi-Cool "digital gauges" there is no question that it is more accurate and faster. Like it or not we are moving to higher efficient 410a (and maybe other refrigerants) in the A/C field. Most Mgf.'s have charging charts on their CU's with SC/temp/SH tables, the higher the SEER the more this is important. Having the ability to hook up the gauges and read out directly pressure, SH & SC with out breaking out charts and all is a big time saver on it's own.
    The Testo 435 IMHO is one of the best tools you could have for airflow measurement. There has been a number of times I have gone behind "Mr. I know everything about airflow" and proved to the HO that they had a problem.
    Your better customers are reading sites like this and are learning that airflow is just as important as equipment. My goal is to sign up better customers!
    TFMM
  12. #38
    after knowledge,
    you're only as good as your tools
  13. #39
    Float'N Vally, MS
    after knowledge,
    That's why when we go into a financial institution and they ask for an asset list.
    I give them a tool list!
    TFMM
