Results 1 to 10 of 10
    May 2009
    variable speed blowers worth it?
    Just moved into a new house. builders grade nordyne system with single speed blowers. SEER 13. installed offered to replace both single speed blowers with a variable speed blower saying increase to SEER 14. cost is $ each blower plus $ for a top of the line honeywell thermostate.
    Is this worth it? what benefit will I get?
    I run the blowers 24/7 and the system is fairly loud with air noise.
    thanks
    Apr 2009
    R.O.T.
    The variable speed blowers can run at a slower speed when run 24/7, decreasing the air noise.
    No prices in post.
    May 2009
    Not sure why. $ for each blower installed. $ for each thermostat installed
    4H: Hot, Humid Houston H.O.
    Having a VS blower would facilitate several things which are useful for humidity removal and/or energy efficiency. As a homeowner I would do it.
    Hope this helps -- Pstu
    Oct 2008
    Indiana
    Quote Originally Posted by russ359 View Post
    Not sure why.
    He's trying to tell you that $ amounts aren't allowed in posts
    Because no prices are allowed.
    Do NOT repost something once a mod tells you not to, and or edits it out of your post.
    Or the post, or thread will be deleted.
    Read the site rules before posting again.
    May 2009
    OK, sorry did nto realize no prices are allowed. But what benefit will I see if I replace the fixed speed blower on a new Gibson unit with the variable speed blower package? I have two units. I'm looking for % electrical savings, better temp distribution, etc
    thanks
    Jun 2007
    Bucks Co PA
    thanks
    I'm a home owner and had a variable speed blower with my new heat pump last July. The difference in noise is incredible, in fact I went to the basement to see if the blower was running at first. LOL
    It helps with humidity reduction by running low speed and keeps the indoor temp fairly even (I only run the fan on auto).
    I believe it saves money, but can't give a figure. I went from an AC system to a heat pump dual fuel see in this thread http://hvac-talk.com/vbb/showthread.php?t=278602 Post#7
    Apr 2009
    Mobile, AL.
    I have a Goodman GMV with heat pump and the variable speed fan is great! It ramps up smoothly and offers the benefits previously mentioned and also if your thermostat supports it it can have programmable fan instead of continuous "on" that will run the fan for X min. out of an hour slowly enough that you will hardly notice it, but enough that the air will not stratify and be stagnant.
    This one feature is almost worth the price of admission. With the other features i think that it is a no brainer, cost savings be d---ed.
