    need major help... no where to turn
    I am installing a digital thermostate and i need some help. my wife thinks that the A/C is running way too long when it is on and that the temperature that the thermostate is saying it is must be off because the house is freezing (according to her)
    I had a manual (mercury) thermostat hooked up. I do not know if I have a multi stage or single stage heat pump so I am kind of confused. What I do know is that when I turn the heat on, if I turn it up a bit higher than needed, a little blue light comes on and it blows really hot, and a technician referred to this as "strips". My guess is that it is an auxilary heat source. It must be electric because I have no gas to me house.
    THe wiring that was hooked up to the original thermostat was as follows:
    Green wire hooked to G on the thermostat
    Red to R
    Blue to B
    Purple was not hooked up
    Brown to X
    White to W2
    Yellow to Y
    I followed the instructions for my new Hunter 44360 thermostat and this is how i have it hooked up:
    There was a jumper from RC to RH, and I left it there
    Yellow to Y/O
    Red to RH
    White & blue wires to W/B
    Brown is not hooked up
    Purple is not hooked up
    There are three switches on the back of the panel. One is for Auot-Recovery and I know what that is. One has options STD or HP. I had it set to both and it did not seem to make a difference. Another switch is the Fan Option and it has HG or HE. I have it on HG.
    PLease, please help me.
    Also email at < No email in post>
    Im not allowed to work on Hunter thermostats, at least not since the fire. Insurance wont cover it. Sorry
    Feb 2005
    Miami, Fl.
    Ya didn't read the rules, did ya.....
    No DIY advice given.
    Thread closed.
