    Philadelphia, PA
    Coleman 9.C blower/fan random cycling
    Coleman 9.C furnace. Thermostat set to heat. Since it is spring the unit hasn't run in the last couple of weeks. Tonight the blower turns on. I checked the thermostat. Still in heat mode but no call for heat. Fan is set to AUTO. Cool air coming from the vents. I go downstairs and listen for awhile. The fan comes on goes off, on, off, on, off. Seems a bit odd so I switched off power to the unit. Just posting to ask if this is a known problem with Coleman/York units.
    Thanks, Mike
    Nope.
    Time to call for service.
    Apr 2009
    F.Y. I.
    factory has no bulletin on this issue, time to call a tech.
    a competent tech will check and test a few things with a meter and be able to remedy your situation.
