Results 27 to 36 of 36
Thread: Subway yeast problem
07-18-2009, 07:15 AM #27
- Feb 2009
- 392
09-19-2009, 11:58 AM #28
- Sep 2009
- 4
Slime and algae are normal for subways due to the yeast from baking bread. The ozone machines work the best for stopping slime and algae. We installed them in 10 subways and have had no issues with slime and algae so far. We got the lights through western pacific distributors. Some stores get so bad that the plates are covered, the trough has a 1/2inch layer, and the pump is completely jammed up. And this occurs within a month and a half after a thorough cleaning.
01-30-2011, 10:00 AM #29
New Guest
- Jan 2011
- 1
Slime & Bacteria is a problem in every restaurant or place that has commercial ice machine, and as stated the problem only gets worst in high yeast environments including bars. The best way as stated before to rid your ice machine of it is to have it cleaned and sanitized on a regular bases, but it is costly. When I used to work at a sub shop, it was a constant battle, and someone’s head seem to always be in the ice machine cleaning it, until we started using an Ice wand slime filter, found them over here http://www.freshwatersystems.com/c-4...inhibitor.aspx . No it is not like other ice machine filters, because slime is a result from air and flowing water in the sump, after the water has been filtered. This slime filter sits in the water sump where treats slime build up from its source. After using it for a year I have to say it works like a charm.
02-01-2011, 09:15 PM #30
Professional Member*
- Oct 2009
- Kingsport, Tennessee
- 129
Graham,
Great post and thanks for a lot of good information. I am both a Subway owner and maintenence guy. haha. The problem is very different from store to store.
I know city water would help too, but Subway ( ugh, sometimes) makes all water be super filtered for all soda and ice. HAS TO BE!
BUT this is good info and I will be calling those people you have mentioned Chas, that sounds like a great product, and I really need that at one location.
jt
02-12-2011, 07:31 PM #31
New Guest
- Dec 2009
- las vegas, N.V.
- 1
people are crazy
We service 40+ subways across las Vegas n have them on a 3 month maintenance found uv lights work well but only where the light contacts inside the trough is still hard to maintain but cutting in a fresh air supply to the head of an ice machine is absurd that's hack tech stuff
02-12-2011, 08:49 PM #32
- Mar 2007
- Toronto
- 258
I would be very curious to see how a Kold-Draft machine would work in a Subway application. The only slime I've ever seen on a Kold-Draft is on the water distribution tube well away from any contact with the ice. The main trouble is mounting the bin stat so it doesn't get demolished by the agitator motor in the dispenser. The main trouble I see is a lack of qualified service people as Kold-Draft has been a very minor player since they crashed in 1991 and is the toughest machine to learn to troubleshoot and their technical support is poor.
03-09-2011, 02:55 PM #33
- Oct 2010
- Florida
- 38
I got rid of slime in ice machines
Try Icezone from Biozone Scientific. This is the only product that I have found to work. It works in Subways and in bars- places where yeast can be out of control and wreak havoc on ice machines.
Contact Best Refrigeration in Springfield Missouri at 800-772-4026 to order Icezone (this is where we get them).
You may also call Biozone Scientific directly at 407-876-2000 to apply to become a distributor.
03-12-2011, 12:49 AM #34
- May 2008
- KY
- 12
I will look into all the advice given. I can say I tried a UV light the last year mounting it right above the water and it made a big difference!!! Maybe had to clean it 3 times a year? Discolored the plastic a bit but no trouble except the light has gone out now so....
03-12-2011, 01:58 PM #35
New Guest
- Mar 2011
- 5
like somone else said there is no substitute for manual cleaning, as a servicer wouldnt you want to have a maintenance agreement with these customers to go and clean there machines every three months? I think that by buying all the things that are supposed to cure this slim problem is a waste of money just clean them! And to who ever said intall a Kold Draft machine in a subway REALLY? Well off to subway to clean some machines!
05-26-2011, 07:45 PM #36
- Oct 2010
- Florida
- 38
