Results 1 to 13 of 19
    Replacing 5 ton trane compressor for copland 5 ton
    Thinking of making the switch before the 1997 trane 1-phase compressor completely dies- Got a price for less than $ after several phone calls and a discount because I have 12 units to maintain- I am looking at replacing trane compressor on xe1000 that is a 56k BTU with a copeland 58k BTU. All other specs match except for roto-lock fittings bit sweating is not a problem.
    Andone one think I will have issues with this- r22 replacement on a 1997 unit that for the most part is still in good shape- new evaporator, new fan blow, new fan motor, capacitors, etc.??
    What does the tech that is doing the swapout think.
    Nov 2008
    Chapel Hill, NC
    Will the existing Trane coil work with the new Copeland compressor? Why Copeland and not another Trane?
    Apr 2008
    TEXAS
    there shouldn't be any problems doing this as long as you realize its not a set up that is going to last another 10 years. if you just want to put off replacement for a couple of years it will work. we have done this dozens of times over the years sticking with r-22 and a recip compressor. if you are thinking of converting this into a r-410a system, thats a whole other ball of wax.
    "When the people find they can vote themselves money,that will herald the end of the republic" - Benjamin Franklin
    "Government is not reason, it is not eloquence, it is force;like fire, a troublesome servant and a fearful master. Never for a moment should it be left to irresponsible action"- George Washington
    Nov 2000
    Eastern PA
    Better figure on adding an accumulator and possibly a discharge muffler to that set up.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Saint Joseph, MI
    Quote Originally Posted by sktn77a View Post
    Because he can save a few $$$.
    He should work for our purchasing department. They bought a large steam control valve and saved $$$,$$$.... but they've already replaced it once and spent $$,$$$ in special equipment to service it... oh and the valve regulates steam pressure in the plant, when it fails the whole plant goes down. Ooops.
    So he might save $$$ now, but if he only get's half the useable life out of hte unit, how much have you saved? Don't forget installation costs.... and if the teneants lose A/C every 5 years, they might do somewhere else. If demand drops, the rent you can charge might drop.
    Nov 2005
    sacramento calif.
    Quote Originally Posted by smittyii View Post
    why would your compressor replacement only last two years? i've heard tech's (well mostly salesmen) say that before but usually when trying to upsell to a new condensing unit. go ahead and assume i'm an astute enough tech that i'm not going to install with the same dirty coils that killed the last comp. and support this remark.
    i was born under a wandrin star.
    Apr 2008
    TEXAS
    Quote Originally Posted by stonefly View Post
    it could last 50 years couldn't it? just not likely, since their system is 10 years old. two years is a way of saying don't expect miracles. btw i have had replacement comps last over ten years. when a customer realizes they have dodged a bullet, they usually start paying more attention to maintenance.
    Apr 2008
    TEXAS
    on the other hand i've seen 30 or 40 straight days of 105 degrees kill a new compressor!
    Nov 2005
    sacramento calif.
    how so?
    central america
    trane comp. replacement
    I have changed alot of older Trane comp to Copeland...requires some field modifacation..piping, suction acc.,comp. hold down bolts, crankcase heater, capacitor..Usally done only as last resort..becauase of availblity, time, money.
    The additional time/parts make it a wash..
    Danfoss/Manuroup compressors are a exact drop in replacements for American Std./Trane cans. With rotolocks , same bolt patterns..Cheaper than Tranes..
    Have had good service out of them...even the 3d scrols.
    Apr 2008
    TEXAS
    how so?
    have you ever been to texas in the summer fella???
    Apr 2008
    TEXAS
    Quote Originally Posted by superheatrman View Post
    they are a good fit, but i can get copeland and bristol locally. i have to go to austin or san antonio for maneurop.
