Thread: Gas pack vs split system
05-01-2009, 09:19 AM #1
- Jan 2007
- 54
Building a new home and have the choice of a gas pack unit or split system is one any better than the other?
05-01-2009, 10:24 AM #2
Professional Member*
- Oct 2006
- The Beach
- 468
Either one will work fine if installed properly. Split unit will require enough height in the crawl space. If house is two story a split works better. A package unit is better to service. Short gas line, no venting problem and no freon lines ( Less chance of leaks). Sometimes a problem in getting the right size return in the crawl space. Large outside unit might be a site problem?
Blue Fox
05-01-2009, 12:53 PM #3
- Feb 2008
- Dallas & Longview, TX
- 627
Like to add that the package units are more limited in efficiency rating. If you're looking for a 21 SEER unit then I don't believe a gas pack is an option.
I "think" the gas packs max at about 15 SEER but didn't look it up so could be off a point or two.
05-01-2009, 01:04 PM #4
05-01-2009, 01:17 PM #5
- Apr 2009
- Texas
- 218
I would consider the length or your duct runs in this decision. With a split system you can usally locate your inside unit (furnace/air handler) in a more central location which shortens your duct runs. It just depends on the lay out of you home. If you have a package unit at one end of a long house and a room with a big heating or cooling load at the other end of the house you may run into problems getting enough air flow to that room.
