Results 1 to 13 of 30
    Worthington Chiller
    1966 Worthington with a V2 Worthington 4 head 8 cylinder compressor. Converted from water cooled to air cooled 20 years ago. Still runs like a champ. Had leak issues and I found a couple but then the one in a place I have never seen. I will post pics when I am done with it in a day or so. Anyhow the leak, on the side of the compressor there is a large plate with 10 or 12 5/8" bolts in it and it has the oil sight glass and then a few weirdly placed bolts. I got the nitro up to 200 psig and when going over it with soap I noticed an oil vapor coming out of an allen head "plug", only the allen head had a hole in it. I was just about to plug this hole with a new "plug" when I noticed that this hole seemed a little too perfect. I called the local compressor re builder and much to my surprise this was and atmosphere port for the capacity control module inside and that it contains a bellows that will wear out over time and leak. Even more surprised they had one in stock (pricey little thing). I again will post pics of all of this when I am done.
    "It's always controls"
    Apr 2006
    Motel 6.5
    I wasn't even born with that was started. Hope it keeps running.
    Me either. I was negative 10.
    Dec 2008
    Dixiana, AL
    I was (I was 6). There was still a trainload of those things around when I first went into the field, so I got to play with several of them. It's my opinion that when they quit makin' Worthington recips, we lost a jewel. Kinda' like the old Trane double-enders - not real efficient, but easy enough to service, and hard to tear up.
    Ok Here are the head pics, More to follow.
    Attachment 27122
    Attachment 27132
    The allen head that is at an angle ( I scraped the paint off so it looks black in the pic) is the port where the leak is.
    Quote Originally Posted by klove View Post
    Not much complicated about them, that is for sure. The only call we normally get (for the chiller anyway) is during the switch over weather, it is a 2 pipe system with the original pneumatics still in tact. Did replace the condenser fan motor a couple years ago, belt drive for 2 fans.
    The South
    Great to see a worthington is still out there running, haven't seen one since way back in my apprentice days- when I walked uphill both ways to school five miles in deep snow blah blah blah....
    Do you have a pic of the entire compressor?
    Ever work on one of those old chrysler hermetic vertical compressors that looked a bit like a small barrell?
    GO DAWGS!
    Quote Originally Posted by HVAC9900 View Post
    Yeah I will post some more as I go through the repair.
    It has been a while since I worked on those Chryslers, had them at the AF base.
    Nov 2008
    I used to work for a Worthigton dealer back in the day.
    If I am not mistaken we used to use the port that you are talking about to hook to a pneumatic receiver controller for external capacity control.(I am sure that is no real help in this case but may be of interest)
    Northwest GA
    It's probably a good thing you didn't plug it. It would build pressure once plugged and load up and not unload. I had a Trane F that someone plugged and couldn't get it to unload. Carrier 5F, Trane F and a few others had this
    port on them for a pneumatic control signal for capacity control. It was actually handy for testing purposes. Put a fitting in and a squeeze bulb with a guage and load and unload at will! Don't have to get the big wrenches out and mess with the suction service valve.
    Delaware
    As I recall, triggerhappy is not mistaken. These compressors operated much like the big iron Trane (Mod E & F) and could incorporate pneumatic unloading using that port. Otherwise it was left open to the atmosphere.
    Quote Originally Posted by Chiller Guy View Post
    As I found while talking to the guy at the local reman shop. He told me Trane bought or borrowed this design later on their compressors. He also did say that they were without a doubt almost bullet proof. Unless you flood the crap out of them with the loader. I think that is what happened to this one.
