Results 1 to 9 of 9
    Apr 2009
    San Antonio
    30GXN325 Reoccuring problem
    its a 30GXN325-A-6-CY spun up July 2003 in a 40K sf office building. Since then I have had to replace 2 screw compressor boards. The most recent burnout is attached. Does anyone else have history with this type of equipment killing its boards in this manner?
    I have other problems with it (motor masters, fan motors, fuses, liquid level sensors, etc.) but generally nothing takes the entire system down except this. Its Texas and not a good thing when AC is down. The last time the board burned up and was down for six days until replacement parts made it. The good thing was it in December. This time its too close to summer to survive on ambient air temperatures.
    May 2008
    Central Pennsylvania
    I take care of quite a few similar chillers as what you are working on except mine are all 30HXC's or 30HXA's. Both models have been reliable especially the water cooled machines. Haven't had any board failures yet and some have quite a few hours on them. My chillers are all inside, maybe the outdoor heat has something to do with it?
    Apr 2009
    San Antonio
    Weather conditions
    thanks for your response. Weather conditions the first time was high of 65 low 39, light rain, and moderate winds per NWS archives, April 24 high was 82 and low of 63 with moderate to high winds, no precip. The wind is the only cross match on environmental conditions.
    Jan 2005
    Houston TX
    30GXN(PITA)325
    Hello fellow Texan, visited your little town about a month ago. Judging by what I'm seeing in you thumb nail that arc-flash has more then control voltage behind it. Check anywhere Line power and 24/120 volt control power occupy the same cavity (ie) Compressor terminal boxes, motormasters you get the idea. Geo.
    East of big city prices.
    Quote Originally Posted by KMS-PL View Post
    Hey KMS-PL put your email in your profile I will see what I can do.
    Oct 2006
    Central Texas
    I've got an account w/ 2 air cooled 30GXN & one 30HXC- had it for the past year, I've never experienced anything like that... sounds like you're shorting out somehow.
    Sic Semper Tyrannis.
    Apr 2009
    San Antonio
    Short somewhere
    Agreed on the short. It appears the 4th pin from the bottom on J9 SCB was the source in December which was significantly less scorching than this one (unnoticable until we removed the board). Fuse 2 is not burned out and we are looking around Oil Heater B for the short. Originally I was told it was J6. My email is up in the profile now. Thanks everyone. I'll post an update later today.
    Apr 2004
    I had a similar machine (carrier screw) where the control board shorted due to burnt out solenoid coils ,the whips were pulling on the stems of the solenoids causing the stem to distort and the plunger wouldnt pull in causing coil failure,watch the whips on those units cause they will create troubles.Anyway good luck.
    There should be a blacj jumper wire going from terminal #5 to terminal #7 cut it as close to #5 as possible . Then spilce that into the black wire with #4 away from the terminal block/J9 plug. Most likely not a short but still possible.
