Results 1 to 13 of 32
    would like some feedback
    Dual W/M 155 Ultra's 5 zones of hydroair and W/M 119 DHW Tank
    Jun 2006
    New Jersey
    Nice install. Only thing I can see wrong, is the pressure reliefs should be in the upright position.
    But I'm sure some others will find more things wrong.
    I think the relief vlvs are fine. thats a nice install! what is that under the window...exchanger? never seen one of them before
    id be worried about somebody accidentally knocking out one of those support bricks under the boilers.
    HVAC PRO IN THE MAKING
    NATE's:
    Gas Heat Service/ Installation
    Air-to-Air Heat Pump Service/ Installation
    Air Conditioning Service/ Installation
    Its a Caleffi Hydro separator
    here is the description on it
    The HydroLink primary/secondary piping package can be used with low-mass boilers serving multicircuit hydronic systems. The device combines a hydronic separator and distribution manifold. It merges the attributes of a low-loss header with isolated secondary circuits in one out-of-the-box unit, which results in guaranteed flow through the boiler to prevent flashing or hot spots and minimum Delta P drop between each secondary circuit to ensure accurate flow. The HydroLink provides a low pressure loss zone, enabling both primary and secondary circuits to be hydraulically independent of one another. The unit operates at a maximum working pressure of 100 psi, and with maximum liquid temperatures of 240°F. The HydroLink is packaged in a painted, welded steel body with an insulation jacket.
    Jun 2006
    New Jersey
    Quote Originally Posted by Profiler View Post
    Our boilers would fail for the reliefs being in the horizontal position. I thought that was national code. Am I wrong?
    Outside The Motor City
    very nice neat work!
    I just don't like OSB; a job like that deserves ac plywood stained to highlight the work!!
    NO Brains NO Headaches
    the boilers are also bolted to 2x4 behind the OSB
    Quote Originally Posted by hvac248 View Post
    Yea the contractor put the wall up for us
    Dec 2006
    Northern VA
    I think it looks great. Shows you have pride in what you do.
    Delaware
    Looks great. Was the homeowner upset with all the wall space you used up?
    Always here
    Indiana
    looks great..would be proud of that also. Prediction: Will have junk piled upon in in 6 months ..your wall of pride piping becomes a place to hang life vest and fishing tackle in 9 months..
    The basement is about 40 X 100 and the utility room is 20x30 need to use it for storage
    Perfect , i would be concered about the blocks though. Awsome job
