Results 1 to 13 of 15
    Jul 2000
    Columbia, SC. USA
    Take a look at these pics: The first one is from the front, This is a 3.0 ton heatpump Air-handler that had been installed in-place of a gas furnace by annother company a couple of years ago....
    The second one is the main reason the customer's electric bill was over four times the normal ammount......
    As you can see the old cooling coil was left in place in the ductwork...not attached to a condensing unit at all...it is filthy, and the gap you see in the ductwork was there when we arrived...there must have been two tons of air coming out of this gaping hole!!!!
    How about the nice insulating job here on these returns!!!
    This gas line isn't capped off...there is no high voltage disconnect.....the indoor coil on the heat-pump is filthy because a filter was never installed.....There was a total of 5 supply ducts lying on the ground, blowing into the crawler.....
    The drain was never hooked up...had drained into the crawler all summer....What a huge mess!!!! It's gonna cost her a bundle to fix it...Have fun fellas!!
    [Edited by Boss on 12-28-2003 at 10:36 PM]
    Jan 2002
    Angry That's so bad it's not even funny
    OMG!
    what a shame...
    Don't forget to check for the correct size service to the a/h and that the circuit breakers are correct size.
    Are permit's req'd for a changeout where you live? Was the elctric co involved (here they will pay the cust $500 to change from gas to electric)
    those hacks should do jail time/community service for that job
    Mar 2002
    is it just me or did the pics disappear?
    alm ii
    Apr 2000
    imagewiz is doing repairs and upgrading, should be okay by tomorrow.
    Boss
    Oct 2001
    Boss
    I thought I broke it! I uploaded the pictures of our Cracker Christmas Dinner, and when I returned to the thread, no one's pictures would work!
    Hindsight is NOT a plan!
    The Alamo
    It may cost alot to have these repairs made but think how much it has cost to run the system this way for all of those years.
    Read, read, read!
    Nov 2002
    Piedmont Triad area of North Carolina
    Talking
    Is that one of the gas fired heat pumps?...
    Unreal!
    Apr 2001
    San Antonio, TX
    I hate calls like that
    Trying to work under a house is bad enough but throw in two dead bodies and you have a nightmare.
    Breeze
    Jun 2002
    Bemidji, Mn
    Wow...... Definetly replace and do it right IMO!
    You picked a fine time to leave me loose wheel...
    http://rapalaguy.spaces.live.com/
    Jun 2002
    Bemidji, Mn
    Re: I hate calls like that
    I hope this didnt happen to you !
    proof that drunks and dopeheads can get employment.rk
    good time to get into mold remediation.
    Southern Utah
    what about the gas line. flex is not supposed to make more than a 90 degree bend. also, the old grey stuff is no longer approved!!
    Worse yet. That wrinkled duct tape. Nothin shows poor workmanship like wrinkled duct tape!
    Watts New, Ohm My, I been Electrically Commutated. Are U2.
