Results 1 to 13 of 16
Thread: Vac-U-Ator
    Jul 2000
    NW IL.
    Vac-U-Ator
    Anyone seen or use this for measuring vacuum?
    Aircraft Mechanical Accessories Technician. The Air Force changed the job title to Air Craft Environmental Systems Technician. But I've decided I'll always be a Mech Acc.
    New to me.
    THE MORE I LEARN
    THE MORE I FIND I DON’T KNOW
    Cancer Survivor
    And Dam Well
    Plan On Staying That Way
    Aug 2000
    Yes, they work well. More accurate/dependable than any digital/electronic vacuum indicater you can buy. JMHO
    Your poor planning does not constitute an emergency on my part!!!!
    Jan 2005
    Here Looks Interesting enough. I would like to see one in action. How exactly does it work.
    Build it and it will break. Fix it and it will work. Ignore it and will cost more. Patch it and it will get worse. Cross the bridge before the flood.
    Grottoes VA
    I say it still looks like a bong.
    Jan 2005
    OH........HMMMM the more messed up you get the better the vac you pulled.
    Aug 2000
    Its a wet bulb vacuum indicator. There is a thermometer in it that is wetted with vacinol. The lower the vacuum, the lower the bioling/evaporation point. 38F is around 6000 microns. There is a chart that relates the temp vs vacuum.
    Jan 2005
    Good Exp Thanks
    las vegas
    anyone know the price on this item ? looks interesting .
    could possibly retire my mercury absolute monometer.
    South Jersey
    Quote Originally Posted by absrbrtek View Post
    Never seen 'em at the supply house...............
    Who has them? Abco maybe?
    Or online/special order only?
    Would like to take a closer look.
    Aug 2000
    Got to email the guy to get delivery and price info. None of the supply houses sell this. Its been around forever, long before electronic ones. All the York books show it in their evacuation procedures.
    Quote Originally Posted by bustawrench1 View Post
    Dec 2008
    Dixiana, AL
    I've had 3 over the years, although mine were made by Humphreys. Good gauges, work with distilled water or vacanol. 35* with distilled water is 5000 microns, -12* on vacanol is 5000 microns. Best to use vacanol or you can't go deep (obviously).
    Jan 2005
    Houston TX
    That's the ticket
    Please read my post on vacuum readings thread. I've seen this device in action on a large system, estimated cost is about $150.00, not bad when when you consider the cost of an accurate electronic meter.-GEO
